  4. How to stop mentioning the via points
5 Posts 2 Posters 69 Views
  • Albert Renting
    Albert Renting
    Albert Renting
    Tijdens gebruik van carplay, krijg ik constant meldingen van '... meters tot routepunt' en 'routepunt bereikt'.
    Hoe kan ik deze meldingen uitzetten?
    • Albert Renting Albert Renting
      @Albert-Renting Go to Navigation settings and open the Audio settings.
      Albert Renting 1 Reply Last reply
        Albert Renting
        Albert Renting
        Albert Renting
        wrote on last edited by Albert Renting
        @Nick-Carthew Okay, I've done that, and I've got the first option (spraakinstructies) activated, the second (spraakinstructies vervangen voor piepjes) en the third one (te hard) de-activated and the last three again activated.
        Should I de-activate the first option (spraakinstructies) as well? Don't I lose all instructions then?
          @Albert-Renting These are the settings that I use. I have shaping points turned off and via points turned on.
            Albert Renting
            Albert Renting
            Albert Renting
            I'll try de-activating the Shapingpoints and try again.
            Thanks!
            Albert Renting
            Albert Renting
              Lluís Casals
              Lluís Casals
