  4. Android - Waypoint Menu Close
4 Posts 2 Posters 59 Views 1 Watching
  • Dave J 0
    Brilliant change (Build 3.2.10 - 158) with being able to close the settings menu with a tap on the map. However, the waypoint' menu opened through the settings menu still appears to require me to scroll to the top of the waypoint list before I can swipe down.
    If I select an 'i' on a waypoint however, then the pop up information can be closed with a tap outside the item field.
    Great if the waypoint list could also be closed by the same tap outside the waypoint list on the map as with the other menus.
    Ducati Multistrada V4 Rally
    iPhone 18 Pro
    CHIGEE AIO-6 LTE
    • Dave J 0 Dave J 0
      @Dave-J-0 yes, that’s completely by design! We expect you to use the map while having the waypoint list open.
      Dragging around the area, tapping on markers etc.
      It would be quite inconvenient if the menu would then close by an accidental tap.
      Dave J 0 1 Reply Last reply
        @Corjan-Meijerink thank you Corjan - I get that now. just wondering if a bigger handle/bar could be put at the top of the waypoint menu so that I could tap to 'go to the top' and then swipe down to close. If I have a lot of waypoints, it can be quite a lot of scrolling to go back to the top to then close the menu. Just a thought 🤔
        iPhone 18 Pro
        CHIGEE AIO-6 LTE
        • Dave J 0 Dave J 0
          @Dave-J-0 thanks for sharing that 🙂
          • Strange translation
          • Undo/Redo tool is hidden
          • Crazy routing
            10.4k
          • Which route is shown?
