  4. US Distance Should be Miles and 10ths of a Mile
20 Posts 9 Posters 123 Views 2 Watching
  • Steve Autera
    Steve Autera
    Steve Autera
    In the US we do not really use yards. The info box that shows the distance to the next turn will shows yards when getting close to the turn. It would be better to shows miles than tenths of a mile (0.9, 0.8, etc.) when getting closer to the turn. We just don’t think of half a mile as some amount of yards. It has half a mile.
    Thanks.
    • Steve Autera Steve Autera
      Thanks.
      @Steve-Autera Interesting how this also differs between the UK and US. I thought at least those countries using miles would align their usage of yards too 😉
      Robin Ashworth Dave J 0 Donald W Stewart 3 Replies Last reply
        Robin Ashworth
        Robin Ashworth
        Robin Ashworth
        @Corjan-Meijerink I'm in Uk and would slightly prefer decimal miles. - That's what the ODO meter shows.
          @Corjan-Meijerink I also agree that decimals would be better with miles rather than feet or yards. I am in the UK also.
          Ducati Multistrada V4 Rally
          iPhone 18 Pro
          CHIGEE AIO-6 LTE
            Donald W Stewart
            Donald W Stewart
            Donald W Stewart
            @Corjan-Meijerink Lets make it unanimous. Odometers read in decimal, so lets use 1/10 mile as opposed to yards. It would be great if the hole world worked in km, but that won't be any time soon
            • paul69
              here in the UK, we mix a lot, driving is miles, as is MPH, but someone may say that a pub is 200metres that way, but wouldn't say the pub is 1 km that way, more likely to say half a mile.
              I agree decimal points for miles please
              K1600 GTL
              Oukitel RT3
              iPhone 13 Pro, carpuride 702b
                Thanks a lot for everybody responding here! The voice of the community is stronger than simply one person requesting something.
                Just to help me out completely: do you ever want yards? Or just show a minimum of 0.1 mile? Or what makes sense? You can imagine that 0.005 miles might look strange 😉 But showing 0.1 miles is still quite a lot distance when having multiple manoeuvres after each other.
                paul69 Steve Autera 2 Replies Last reply
                  this might have to be a show of hands,
                  short distances, would not make much sense to me, if it tells me, " turn left in 0.06 miles away", but I would be able to judge "turn left in 100 metres".
                  this is what I mean, that in the uk we mix it up,
                  I might tell someone "there is a T junction in half a mile, turn left and the entrance is 50 metres on the left.
                  confusing!!!!
                  K1600 GTL
                  Oukitel RT3
                  Con Hennekens Corjan Meijerink 2 Replies Last reply
                  • paul69 paul69
                    confusing!!!!
                    @paul-69 said in US Distance Should be Miles and 10ths of a Mile:
                    confusing!!!!
                    YES! Go Metric, please! 🤣
                      Steve Autera
                      Steve Autera
                      Steve Autera
                      Hello, for distances below 1/10th of a mile I would prefer to see feet.
                      Thanks
                      • Nick Carthew
                        It’s easy, 1/10th of a mile is 176 yards
                        2/10ths are 352 yards
                        3/10ths are 528 yards
                        4/10ths are 704 yards
                        5/10ths are 880 yards.
                        1/4 of a mile is 440 yards.
                        1/2 a mile is 880 yards.
                        3/4 of a mile is 1320 yards.
                        Personally, I could settle for any distance from 1 mile or over could be expressed with 1/0ths example 2.7 miles.
                        For distances under 1 mile use yards (or metres)
                        Imperial measurements.
                        There are 16 ounces in a pound, not to be confused with our currency.
                        12 inches to a foot not to be confused with the one on the end of your leg.
                        8 pints = 1 gallon
                        The Imperial pint contains 20 British fluid oz equal to 28.413 ml each. The American pint, by contrast, contains 16 US fluid oz equal to 29.574 ml each. This makes the US fluid ounce 4% larger than the Imperial one. The Imperial pint is approximately 20% larger than the US pint.
                        Fresh water freezes at 32 degrees Fahrenheit and boils at 212 degrees Fahrenheit.
                        Whoever invented the metric system is completely off their heads.
                        We like to keep things simple in the UK
                        • paul69 paul69
                          confusing!!!!
                          @paul-69 But….that is meters? So you use miles, yards, feet and meters? 😅
                          @Steve-Autera And now we’re using feet.
                          Damn, this is getting so confusing! 🙂
                          paul69 1 Reply Last reply
                            So the options are:
                            • leave as it is right now. Measurement in miles and everything below 1 mile is displayed in yards
                            • do not use yards but keep displaying miles till 0.1 mile, then use feet
                            • same as above but meters instead of feet
                            Given the limitations of the website (merely distinguish between metric and imperial) the solution needs to satisfy UK and US 😉
                              So the options are:
                              @Corjan-Meijerink said in US Distance Should be Miles and 10ths of a Mile:
                              So the options are:
                              I would prefer option 3 even though it’s probably the most difficult to implement 🫢
                              Sorry mate.
                              Dave J 0 1 Reply Last reply
                              • Stefan Hummelink
                                Muhahahaha I just can't help but link this awesome sketch regarding metric vs. Imperial.
                                https://youtu.be/GDUt-Kbxqsg
                                Jason, Jason, Jason..... Just watch the video. 😁
                                  @StefanHummelink said in US Distance Should be Miles and 10ths of a Mile:
                                  Nailed it - well done Jason.
                                    yes unfortunately I do, so I might not be much help on this,
                                    K1600 GTL
                                    Oukitel RT3
                                    • Steve Autera
                                      Steve Autera
                                      Steve Autera
                                      Prefer option 2 - miles, 10ths of a mile, and below 1/10 use feet. 🙂
                                        So the options are:
                                        Sorry mate.
                                        @Nick-Carthew I agree with you Nick Option 3 would be my preferred choice from the list although Option 2 would be ok but better as yds.
                                        @Corjan-Meijerink As another thought however, you could have the distance broken down by 3/4, 1/2, and 1/4 mile/km to go with meters, yards or feet below the 1/4 mile/km. Unfortunately, the imperial versus metric debate will prevail as US uses Imperial but the UK adopted metric apart from our road system and some alcoholic drink measures. I was brought up with the metric system so I would prefer meters as the closer breakdown but that will depend on your background, as well as outdoor experience (maps etc). I had a quick look at TomTom and it provide 3/4, 1/2 etc but Garmin provides just metric and Imperial in yds (I think) as whole and 0.5.
                                        Not sure that you will be able to provide the configuration that everyone wants but the key appears to be having a good warning and idea of when the turn is, particularly when there are a lot of turns in the same direction close together. It would be useful to know how configurable this aspect can be made from your Progammer’s perspective as this will be the driver?
                                        iPhone 18 Pro
                                        CHIGEE AIO-6 LTE
                                          @StefanHummelink, barleycorn is new to me 😉
                                          The best part: "You wanted it simple", "It's too late for that" 🤣 🤣
                                          Robin Ashworth
                                          Robin Ashworth
                                          Steve Autera
                                          Steve Autera
                                          Donald W Stewart
                                          Donald W Stewart
                                          • Help please, new user
                                            Bull Tahr
                                            Bull Tahr
                                          • My Routeapp Stays questions
