  4. backbutton goes straight to homescreen
3 Posts 2 Posters 86 Views
    After having navigated with next, pushing the Android back button takes you straight to the Android homescreen, leaving MRA Mobile active in the background. However taking the "long way" by pushing the 3-dot menu and the red button "Stop navigation" and pressing "Yes I confirm" leads you back to the MRA homescreen with the map at your current position.
    I would expect the same action for both methods.
      @Con-Hennekens Thanks for sharing. We'll check the default Android back button usage and adjust where necessary! 🙂
        The issue has been fixed in the upcoming update! 🎉 We aim to release it at the end of this week 🙂
          Alderweireld Rudi 0
          Alderweireld Rudi 0
        • Minimap
          LE DIZES Freddy
          LE DIZES Freddy
          Erdna
          Erdna
        • F042 Is it possible to also display POIs on the library map?
        • Map movement
