  3. Suggestion: Change colour and transparency of main route
17 Posts 10 Posters 4.4k Views 1 Watching
  • Will Brooksundefined Offline
    Will Brooks
    When you plot a route the route line is fixed as black and transparency level. Being able to change the colour and transparency of the route line would be really helpful to suit the different colours used by TomTom, Here and Google maps.
    We can change colour and transparency of routes that you add into an existing route using the "Add Route" function in the left hand menu.
    • MyRoute-app communityundefined Offline
      Administrator
      Hi Will, thanks for this suggestion. I'm adding it to the great list.
      • Will Brooksundefined Will Brooks
        Nick Carthewundefined Offline
        @Will-Brooks You can adjust the transparency using a tool in the toolkit.
        • Sven vundefined Offline
          Sven v
          Is the change of the route colour still not possible ?
          • Sven vundefined Sven v
            @sven-v No, not yet but as I answered above, the transparency can be adjusted.
            Martin van der Lindenundefined 1 Reply Last reply
              Martin van der Lindenundefined Offline
              @nick-carthew will it come anytime soon now? Changing route line color?
              Nick Carthewundefined Con Hennekensundefined 2 Replies Last reply
              • Martin van der Lindenundefined Martin van der Linden
                @martin-van-der-linden I don’t think so. It isn’t on the current roadmap. https://myrouteapp.ac-page.com/roadmap-main-page
                  @martin-van-der-linden said in Suggestion: Change colour and transparency of main route:
                  I have looked at the route line color on the different maps, and it has good visibility on all maps as it is. Maybe if you explain why this is an urgent matter for you, people would understand the improvement it could bring. For now I don't see the urgency but that can change with a good motivation.
                  PAD 0undefined 1 Reply Last reply
                    PAD 0undefined Offline
                    PAD 0
                    @con-hennekens I wouldn’t want to speak for @Martin-van-der-Linden, but for me this goes hand in hand with planning/working with/presenting multiple routes, multi day routes and route segments. For instance, a long group ride route that might deter some, with options to take short cuts to a selection of rendezvous points. It’s all basic BaseCamp stuff really. All routes being visible on the map view when a ‘parent’ folder is selected being another related feature that is missing.
                    Such things are of vastly greater value and use to me, and I suspect for many others too, than all this press a button, ‘lucky dip’ approach that quickly yields a route of sorts. How do you know it’s a good route? What are the criteria used and how do they compare to an individual’s? How well did the originator(s) of such auto-generated routes know the region? I’ve looked at such things from MRA and numerous other sources and they always fall short. There’s no substitute for a bit of effort.
                    Inge Bakermansundefined Con Hennekensundefined 2 Replies Last reply
                    • PAD 0undefined PAD 0
                      Inge Bakermansundefined Offline
                      Inge Bakermans
                      @pad-0 said in Suggestion: Change colour and transparency of main route:
                      Absolutely agree with this - would love these options as well - especially "All routes being visible on the map view when a ‘parent’ folder is selected "
                        Like I said, urgency can change with good motivation 😉
                        Especially the "all routes being visible when a parrent folder is selected" would be quite useful, and make coloring the individual routes meaningful.
                        I do have some experience with Basecamp (mostly agonizing...), but from some years ago. I have never seen (or forgotten about) anything like the described feature in Basecamp though.
                        Jack van Tilburgundefined PAD 0undefined 3 Replies Last reply
                          Jack van Tilburg
                          @con-hennekens said in Suggestion: Change colour and transparency of main route:
                          Do you mean like this.
                          Screenshot from Basecamp. Life Wales routes in one folder with different colors.
                            Jack van Tilburg
                            And if you are a RouteExpert
                            @jack-van-tilburg said in MRA Navigation and downloaded maps.:
                            I often read between the lines that requests from RouteExperts are highly valued.
                            Does that concern the entire group of Experts?
                            you read it right 😊 😉
                              PAD 0
                              @con-hennekens I have always got on fine with BaseCamp, but readily admit that it has a steep learning curve. Probably several! Time and effort invested bring worthwhile rewards in my experience though. But here’s the thing… As I said recently, MRA’s studying and including BaseCamp features but making them more intuitive and accessible has to be a very attractive prospect for generating new subscribers, surely? 🤷
                                I always fell off the learning curve during the winter months. Had to start over watching tuturials over and over again each season 😉 And that while I am quite handy with lots of other software, being an IT guy... I don't have that problem with MRA.
                                I think MRA development is best done by MRA's own vision, but surely they are peeking at others and the community as well. They could probably balance the priorities a bit better indeed.
                                  PAD 0
                                  @con-hennekens Sure, BaseCamp is anything but intuitive. At the time I started using it, I rode quite high annual mileage and all year round so no winter layoffs. Now it”s ingrained. Though, even after all this time, I still find and am pointed to new tricks and even features! Routeplanner is streets ahead (sorry, bad pun) in ease of use.
                                  • FrankSundefined Offline
                                    FrankS
                                    wrote on last edited by FrankS
                                    Hello everyone,
                                    if the option to change the route colour has lower priority in the feature roadmap - which I completely understand - I would however request that MRA changes the colour of blocked streets:
                                    Blocked streets are currently shown in black, i.e. in the same colour like the route (with 0% or 20% transparency). See attached example with the blocked street right to my route.
                                    Like other maps, I suggest that MRA shows blocked streets in red colour and wider than the route line, so that one can see them immediately when planning a route. Currently, I don't see a blocked street on my planned route. So eventually my GPS notifies when I start my ride, which is when I everytime get mad about MRA.
                                    Looking forward to MRA's feedback.
                                    Best regards
                                    Will Brooks
                                    Inge Bakermans
                                    Jack van Tilburg
                                    FrankSundefined
                                    FrankS
                                    PAD 0undefined
                                    PAD 0
                                    Sven vundefined
                                    Sven v
                                      haweboundefined
                                      hawebo
                                      John S Parryundefined
                                      7.9k
                                      supergundefined
                                    • Updated beta! 5.2.1 (486)
                                      632
                                      BrandonCameronundefined
                                      BrandonCameron
                                    • Embedding daily routes into a whole trip route file - How do I do this?
                                      undefined
