  3. POIs without routes
POIs without routes
4 Posts 2 Posters 695 Views
  • Colin Irvine
    Colin Irvine
    Colin Irvine
    I'd like to upload around 20 POIs, see how they're spread out, and then create a route from some of them. However, every time I load the POIs MRA turns them into a long complicated route. How can I stop it doing this?
    • Colin Irvine Colin Irvine
      @Colin-Irvine said in POIs without routes:
      When you choose to upload POIs make sure that you use the POI tab.
      When they upload they will go to your POI library. Tick the box to see them on the map and then add route points to navigate between them. You will need to click on each POI that you want to add to the route.
      • Colin Irvine
        Colin Irvine
        Colin Irvine
        Thanks, Nick. I should have spotted that. One last question - is there a way to load the POIs other than when zoomed in close?
          @Colin-Irvine No, not at the moment.
          Colin Irvine
          Colin Irvine
            769
            610
          • mijn routes overzetten naar de nieuwe planner
            ValléeDesFées
            ValléeDesFées
          • MRA Route planner Next
            peha
            peha
            Barto
            Barto
