  3. Help. No POIs when open route
8 Posts 4 Posters 1.1k Views
  • Joan a Offline
    Joan a Offline
    Joan a
    I'm pretty new using Myroute app. Since a few days when I open a route with POIs added on my Android phone the POIs are not showed. If I open the same route trough route lab then yes the POIs are showed. I got gold menbership
    Thanks to anyone that can help me.
    • Joan a Joan a
      Steve Lynch Offline
      Steve Lynch Offline
      Steve Lynch
      @Joan-a
      The POI's are only visible at the planning stage in the RoutePlanner not in MRA Navigation.
      Most people use coloured waypoints to indicate different types of stops.
      There is a default set of colours that the RouteXperts use but I prefer a more simplistic approach with my colours.
      Personally I never add Via Points (Waypoints that you must go to) which are the Hand Icons but generally most people do use them. The first and last waypoints of a route are always Via Points.
      RoutePlanner
      MRA Navigation
      • Steve Lynch Steve Lynch
        @Joan-a
        RoutePlanner
        MRA Navigation
        Nick Carthew Offline
        @Steve-Lynch said in Help. No POIs when open route:
        @Joan-a
        POIs are visible in MRA Navigation
          @Joan-a
          Steve Lynch Offline
          Steve Lynch Offline
          Steve Lynch
          @Nick-Carthew
          That’s strange then as my fuel poi’s do not show up on my Android phone in the MRA Navigation screenshot above?
          Am I missing something?
          Apologies to @Joan a therefore!
          Edit: Ah I think get it, I have to add the blue Fuel icon for them to appear as POI’s.
          I don’t actually use them generally as the colours in MRA Nav suffice for me in tandem with the XT.
          • Joan a Offline
            Joan a Offline
            Joan a
            Thanks Steve and Nick.
            My problem is not with MRA Navigation, I don't use it. My problem is with MyRoute app. When I open a route on the map the POI's added do not show. When I open the same route trough Route Lab then yes I can see the POI's. What I would like is to see the POI's on the map page so I can follow the route seeing the POI's. I think a few days ago I could do this but no now.
            • Joan a Joan a
              @Joan-a said in Help. No POIs when open route:
              I think that you are referring to MRA Mobile when you mention not being able to see POIs on the map. Can I ask why you need to see POIs to follow the route?
              Joan a 1 Reply Last reply
              • Corjan Meijerink Offline
                Thanks for your suggestion! We will add POI's and additional waypoint info to the route loaded in MyRoute-app Mobile in an upcoming update. It however isn't included in the next one.
                  Joan a Offline
                  Joan a Offline
                  Joan a
                  @Nick-Carthew
                  Hi Nick. Yes, of course. I'm planning a trip to Nord Cape and I like to put POIs around the route like gas stations, càmpings, parquings, etc. In such a long trip I don't know exactly where I'll need refill my tank, sleep, buy food, etc. So, I add the POIs around my way
                  Steve Lynch
                  Steve Lynch
                  Joan a
                  Joan a
                  • Interesting behaviour on a pre-planned route that uses the same road in both directions
                  • Onbegrijpelijke afslagen
                  • Stemgeluid sterker bij afspelen muziek
                  • GPX1.2 & Garmin Tread
                    MTC-Zeilberg
                    MTC-Zeilberg
                    Huibertus
                    Huibertus
                  • Update 5.2.1 - Android availability
                    TomOnTour
                    TomOnTour
