  3. How do i transfer route from the MRA planner to MRA navigation
7 Posts 6 Posters 1.4k Views 1 Watching
  • Brian Albee
    Brian Albee
    Brian Albee
    If i make a route in the MRA planner how do i transfer it to the MRA navigation to use with my phone...and yes i have the navigation
    Reinhard-32 TorqueRider 2 Replies Last reply
    • Brian Albee Brian Albee
      Reinhard-32
      Reinhard-32
      Reinhard-32
      @brian-albee On your Phone log in your MRA account and you have access to your routes.
      Kindly regards
      Reinhard
      Montana 700i and Mac
        @brian-albee
        Hi, did you see the tutorials in the support section?
        For example: Getting started with the MRA Navigation app.
        • Bouke Ent
          only negative about navigation is that you have no folders but last changed route will be up. i do not like this but before you go always make small change and route will be up in list. i realy i hope the will give same folders in planner as in navigation
          • Bouke Ent Bouke Ent
            @bouke-ent said in How do i transfer route from the MRA planner to MRA navigation:
            If you are going on a tour with several routes, you can create an event and add all of the tour routes, then all of the tour routes are easy to find. Not perfect, but it is a good workaround.
            Bouke Ent 1 Reply Last reply
              @nick-carthew thanks for idea. i will test this in next trip.
                ... before you go always make small change and route will be up in list.
                Indeed, and clicking "Edit" (the pencil) and then "Save" without actually changing anything, suffices.
                Reinhard-32
                Reinhard-32
                Brian Albee
                Brian Albee
                  martin-phogel.de
                  martin-phogel.de
                  12.0k
                • F004 MRA Navigation Error
                • Probleem met eigen Stay
                  Albert van den Elsen
                • Reclame van Navigation Next blokkeert de navigatie.
