  3. My Route Takes the Wrong Ferry = How Fix?
2 Posts 2 Posters 776 Views
  • John Gower 0
    John Gower 0
    John Gower 0
    Using MyRoute across ferry journey it often uses the wrong ferry and backtracks to a totaly different ferry. The only way to (currently) fix this is to break the route either side of each ferry. This is particularly a problem on the Scotttish islands ferries.
    The problem is that the ferry route data in MyRoute is clearly incomplete or inadequte. When is this going to be fixed?
    • John Gower 0 John Gower 0
      @John-Gower-0 Place a route point at the landing place of the ferry and then use the ‘skip’ function on that RP. 1D83B6E4-ED03-454C-B868-35992AB7EB6F.png
      John Gower 0
      John Gower 0
        silberfuchs67
        silberfuchs67
        490
      • Statement on map spinning
        1.8k
        Barto
        Barto
      • MRA Route planner Next
        peha
        peha
