  2. Routes & Tracks
  3. Search Routes in Left Side Bar Menu
9 Posts 4 Posters 2.1k Views 2 Watching
  • Scott Tracey
    Scott Tracey
    Scott Tracey
    I like to use the function where you can overlay an existing route onto one that you are planning. The down side of this function is that I cannot search for a route by any means other than scrolling through.
    does a search function exist or is it not available?
    Reinhard-32 Nick Carthew 2 Replies Last reply
    • Scott Tracey Scott Tracey
      Reinhard-32
      Reinhard-32
      Reinhard-32
      This post is deleted!
        @scott-tracey Unfortunately not. If you use more folders then the routes are a little easier to find.
        Scott Tracey 1 Reply Last reply
          Scott Tracey
          Scott Tracey
          Scott Tracey
          @nick-carthew its a shame, I do have lots of folders and sub folders, it just means that there's a lot of clicking to get what you need. It would be useful if you could select multiple files at once but that's no allowed either
          Exilfranke 1 Reply Last reply
            Exilfranke
            Exilfranke
            Exilfranke
            I'm fully with @scott-tracey .
            I also use this very often, but the behavior of this routes box could be improved significantly.
            I often want to overlay (underlay?) my planning with multiple routes.
            Not only that I have to add them all one-by-one, it doesn't even memorize the last folder, but always starts from the root.
            Memorizing the last folder could already help a lot and should be comparably easy.
            For me(!) this would be a big usability improvement.
            Cheers, Sven
            • Exilfranke Exilfranke
              Exilfranke
              Exilfranke
              Exilfranke
              @Hans-van-de-Ven-MRA-Master
              Hi Hans,
              there seems to a high demand/support for improving the route box.
              Could you forward this request to the developers, or product team?
              Cheers, Sven
                Hi Hans,
                @exilfranke said in Search Routes in Left Side Bar Menu:
                Hi Hans,
                5 agreements on a post is not exactly ’high demand’!
                I will pass it on to the developers though.
                • Nick Carthew
                  Requested a search bar and to remember last folder visited. This may take a little while as the developers are busy working on other things, but it has been noted and should be implemented as soon as is possible.
                    Exilfranke
                    Exilfranke
                    Exilfranke
                    @nick-carthew
                    Thanks a lot Nick!
                    Cheers, Sven
                    With your input, this post could be even better đŸ’—
                    Reinhard-32
                    Reinhard-32
                    Exilfranke
                    Exilfranke
                    Scott Tracey
                    Scott Tracey
                      Vincible
                      Vincible
