  3. Route won't map over canal?
5 Posts 4 Posters 931 Views
  • Martin P Williams
    Martin P Williams
    Martin P Williams
    Having issues with MyRouteApp not mapping a route along a road because there's a canal. There's a road and bridge with no issues. Route redirects around the "issue".Capture.PNG
    Does anyone else have these issues with mapping?
    • Martin P Williams Martin P Williams
      Steve Lynch
      Steve Lynch
      Steve Lynch
      @Martin-P-Williams
      Both the Here Map and the Tom Tom Map will route across that bridge.
      If you have a Gold Account you could use Here or Tom Tom.
      Not sure what the issue is with OSM but there are many users here far more experienced in identifying OSM issues, I’m sure someone will work it out.
      • Martin P Williams
        Martin P Williams
        Martin P Williams
        Ah great yes used HERE to map instead.
        Thanks!
          Thanks!
          @Martin-P-Williams What device do you use for navigation? The reason I ask is because you were planning on the OpenStreetMap. If you use MRA Navigation, Garmin or any of it’s derivatives, then you should plan with the Here map. For TomTom devices obviously the TT map.
          • alexsadi
            alexsadi
            alexsadi
            wrote on last edited by alexsadi
            This post is deleted!
            Steve Lynch
            Steve Lynch
            alexsadi
            alexsadi
            Martin P Williams
            Martin P Williams
              11.9k
            • F004 MRA Navigation Error
            • Probleem met eigen Stay
              Albert van den Elsen
            • POI functie 'strict'
