  3. Waypoint menu error on merged routes
7 Posts 4 Posters 1.3k Views 2 Watching
  • Christian S.
    Christian S.
    Christian S.
    The new waypoint menu does not work properly on merged routes. Deleting, recoloring and changing from via to stop or vice versa does not always work. The information "Waypoint deleted" appears, but the waypoint remains in the route. Sometimes it helps to reload the route, then the waypoint is deleted. Sometimes it is also necessary to log in again for the changes to take effect.
    The problem only occurs with routes in which routes have been merged. With "normal" routes the waypoint menu works without problems.
    • Christian S. Christian S.
      Steve Lynch
      Steve Lynch
      Steve Lynch
      @Christian-Schrenk
      I have checked a merged route and you are correct.
      You should create a support ticket for this as then it will go straight to the developers.
      Christian S. 1 Reply Last reply
      • Steve Lynch Steve Lynch
        @Christian-Schrenk
        Christian S.
        Christian S.
        Christian S.
        @Steve-Lynch
        Thanks for the note, I've just opened a support ticket for this.
          @Steve-Lynch
          @christian-schrenk @Steve-Lynch This has now been fixed.
            Christian S.
            Christian S.
            Christian S.
            @nick-carthew
            I just tested this. It works with newly created routes. I still have some problems with existing routes.
              @nick-carthew
              @christian-schrenk
              Works great here, both with old and new routes
                @christian-schrenk
                Christian S.
                Christian S.
                Christian S.
                @hans-van-de-ven-mra-master
                I just noticed something interesting. I copied and renamed the route where I still have problems deleting waypoints. With the copied route, deleting the waypoints works without any problems, with the original route the problem still exists.
                Christian S.
                Christian S.
                Steve Lynch
                Steve Lynch
                  11.9k
                • F004 MRA Navigation Error
                • Probleem met eigen Stay
                  Albert van den Elsen
                • POI functie 'strict'
