  3. How to handle the tet routes
6 Posts 4 Posters 3.0k Views 3 Watching
  • Arjan de Vries
    Arjan de Vries
    Arjan de Vries
    When I import the TET track it first is visible as a track in MRA. If I want to work on it it makes it to a route but it changes the route drimaticaly. Probably MRA does not like the off road routes. How can I make it to a route and still use it? So a route including off road?
    Arjan
    Steve Lynch MotoCon 2 Replies Last reply
      Arjan
      Steve Lynch
      Steve Lynch
      Steve Lynch
      @Arjan-de-Vries
      That would depend on what device you are using to navigate.
      The majority of hardware navigation devices will only plot routes on “proper” roads.
      There are some Garmin Devices that can do it like the Montana range and also the Garmin Zumo XT.
      These devices can display the off-road track.
      I have never used any of the Garmin Montana devices but I have done it on the Garmin Zumo XT.
      Basically you get to see the track on the map and you just follow it visually, it does not give you any turn notifications or voice prompts.
      There are a quite a few Phone Apps that can plot/import off road routes.
      Here’s 2 that popped up Googling “GPX Off Road Navigation Apps”.
      ONX (iOS & Android)
      Gaia GPS (iOS & Android)
      The only “Off-Road” App I personally use, other than the TET App, is OSMaps which is UK specific only.
      I don’t use MRA for Off Road stuff I go direct to the Garmin XT from GPX files saved on my PC.
      In theory you could do it in MRA but the issue is that the Open Street Maps gives no indication of off road tracks that Motorcycles can and cant travel on and not all tracks appear on it in full. (This may be UK Specific)
      Below is an example of my Garmin Zumo XT with every “Green Lane” individually plotted in the OS Maps app for Salisbury Plain and placed into a Garmin Collection to make them all visible on the Garmin XT Map.
      As mentioned above, you get no turn by turn notifications or voice prompts you simply visually follow the red lines.
        Arjan
        @Arjan-de-Vries, No MRA does not like Offroad routes indeed. It is possible to use a piece of offroad within a regular route, but if you need to navigate ar create offroad tracks, MRA is not the tool for that. Sorry.
          Arjan de Vries
          Arjan de Vries
          Arjan de Vries
          @Con-Hennekens Well, better use basecamp then! I am an old basecamp user so I can manage the software.
          • HABVEN aka MrMRA
            @Arjan-de-Vries use the off-road option in the toolbox, you wil get straight lines then
              Oh yes, I may have been a bit too harsh in what I said earlier. I was under the impression that waypoints had to be skipped one by one, but as @Hans-van-de-Ven-MRA-Master pointed out, you can put the whole route into offline-mode through the toolkit. Then, if you are Gold member you can change to the TOPO map and with that you have a much better terrain view. I think it is pretty similar to Basecamp afterall.
              Arjan de Vries
              Arjan de Vries
              Steve Lynch
              Steve Lynch
              • Kaart niet zichtbaar
              • Xpert overlay not clear
                Corrado Miniati 0
                Corrado Miniati 0
              • Google maps
                Ed Bos 0
                Ed Bos 0
              • Trains like Ferries?
                Corrado Miniati 0
                Corrado Miniati 0
