  2. Routes & Tracks
  3. gpx points
gpx points
5 Posts 2 Posters 2.7k Views 1 Watching
  • Cristiano Repetti
    Cristiano Repetti
    Cristiano Repetti
    How to see the amount of gps points in a GPX file generated from myroute?
    I have a navi that not support too much points. Some route I made in MyRoute are not readable.
    How to see how much points are in a track?
    • Cristiano Repetti Cristiano Repetti
      @Cristiano-Repetti There will be hundreds if not thousands of .gpx files. What GPS device are you using?
      Cristiano Repetti 1 Reply Last reply
        Cristiano Repetti
        Cristiano Repetti
        Cristiano Repetti
        @Nick-Carthew Zumo XT. Some GPX aren't read. Probably too much points. Zumo XT accept 10.000 max.
        There is a way in MyRoute to see how many points will be exported in gpx? So I can reduce the track or divide it in 2.
          @Cristiano-Repetti I have not seen this problem before. How many kilometres is your route?
            @Cristiano-Repetti Could you share your route so that it would be easier for me or someone else to offer better advice.
            Cristiano Repetti
            Cristiano Repetti
              Vincible
              Vincible
