  2. Routes & Tracks
  3. What am I doing wrong with Route Tracking
7 Posts 5 Posters 2.8k Views 1 Watching
  • David Rudgley
    David Rudgley
    David Rudgley
    wrote on last edited by David Rudgley
    Hi, I start a route track on my Android App and let it run in the background while using TomTom Go App. On Route I check that the route tracking is working and all seems fine. After a brief stop at my destination I return home. The round trip was around 125 miles. When I get home I check on the Tracker and it shows an A to B straight line route from home to the destination. This has happened twice. I have tested on shorter routes and it works fine. At what point does it abandon the route detail and revert to A-B straight line
    What I did
    What the Tracker recorded
    MRA Gold Planner + App + Navigation Next user
    Android Pixel 10 Pro Fold
    TomTomGo as backup
    KTM 1290 Super Adventure S
    Quad Lock + Phone + Carpuride W702
    2026 Kawasaki Z900 RS
    Beeline Moto II
    Nick Carthew Drabslab 2 Replies Last reply
    • David Rudgley David Rudgley
      What I did
      @David-Rudgley I suspect that your phone can't handle two apps running gps at the same time.
        What I did
        Drabslab
        Drabslab
        Drabslab
        @David-Rudgley I expect that the TomTom Go Appis monopolising the GPS in your android device but this seems like a question for a TomTom forum.
        • HABVEN aka MrMRA
          @David-Rudgley Did you start the tracking in the MRA Mobile App? Did you see that "tracking" was on?
          Because if you create a new tracklog, without starting it, and then finish the tracklog, you get a straight line. The same happens if you push "pauze" and forget to start again.
          David Rudgley 1 Reply Last reply
            David Rudgley
            David Rudgley
            David Rudgley
            @Hans-van-de-Ven-MRA-Master I checked the tracker once on the out leg and it appeared to be recording the route fine. It wasn't until I completed the trip and I finished the track when it showed the straight line A to B track
            TomTomGo as backup
            Beeline Moto II
              @David-Rudgley
              Try both app seperate to check if it works then
              • Simon Cheneler
                Simon Cheneler
                Simon Cheneler
                This has just started to happen on mine using android phone and it was working ok. I search and follow route on navigation and record route but at the end it's now just a straight line or it can just stop recording at anytime and the route is all over the place not even the roads i was on and there is nothing wrong with my phone and google maps, waze tomtom are all ok. uninstalled, re installed still the same.
                David Rudgley
                David Rudgley
                Drabslab
                Drabslab
                Simon Cheneler
                Simon Cheneler
                  Vincible
                  Vincible
