  4. Problem with announcing via points
25 Posts 6 Posters 4.0k Views 3 Watching
    @Marinus-van-Deudekom, great test thanks. It would be interesting to repeat that test with "Navigate route as track" enabled. I suspect that in that case the outcome is like @Gerard-van-der-Veer experiences.
    @Con-Hennekens I will do a similar test tonight as requested. Not the same route but with the same things in it
    • Gerard van der Veerundefined Gerard van der Veer
      I did some experimenting myself and went through all the settings again. I must have changed something along the way, because it’s working now!
      I suspect — though I’m not completely sure — that the slider for “Use all route points” was set to the left. The strange thing is that this slider shows “Off” in both the left and right positions. I’m not entirely sure what its exact function is or whether it’s actually relevant in this case, but when riding a route now I can see the shaping points, which I couldn’t see before.
      Long story short: I don’t know exactly what was wrong, but it’s working now.
      Thanks again everyone for the tremendous help and for thinking along with me!
      Nick Carthewundefined Offline
      @Gerard-van-der-Veer said in Problem with announcing via points:
      Use all waypoints is a setting associated with Navigate routes as tracks.
      It shows both shaping points as well as via points when navigating a track and can only be selected if you have also selected Navigate routes as tracks.
        If you mean that it is greyed out, you definitely have "Navigate route as track enabled". So you are riding a track after all... I am still not convinced that the announcements work like intended for a route, but if it is, that's very good to know.
        • Gerard van der Veerundefined Offline
          Gerard van der Veer
          I'll test that setting too, tomorrow and report back here.
            Second test tonight
            Using option ride route as a track
            The first viapoint without shapingpoints in 2 km. The viapoint was vallen out as expected.
            The end Viapoint with 2 shapingpoints in the 2 km before was never calédonien during the route. Just when ariving there it was called out. Just like you expected @Con-Hennekens
            So the conclusion is that @Gerard-van-der-Veer most likely drive his route as a track
            Guzzistundefined
            Gerard van der Veer
              RideToPortugal.comundefined
              RideToPortugal.com
              AWDC LAOundefined
            • Routepunten
              Leike Lodiersundefined
            • Audio cuttet via Bluetooth
              Haugundefined
              Haug
              15.3k
              AWDC LAOundefined
            • MRA Shop für Merchandise geschlossen ?
              Lenny Oundefined
              Lenny O
            • Iphone looses connection to mobile network when connecting to CarPlay
              Keith Hofgartnerundefined
              Keith Hofgartner
