Way points and shaping points unable to create route
Hi, I've been planning beta routes and have encountered a problem I've never experienced before when creating a route.
So by placing way points/shaping along a route, I found a junction where I wanted to turn right and, no matter what I did, the route will not turn right, but will turn left and turn me higher up the road to get back on myself.Is this a flow!!!
@GiddyKid Sharing your route is the easiest way to get an answer.
Make your routes privacy public and share the URL here. Don’t forget to say where the problem is. -
Either the road isn’t on the map you’re using to plan your route, there’s a driving ban, the road is closed, or it conflicts with the routes you’re trying to avoid.
Which map are you using to plan your route? And which overlay?
As Nick says, it’s best to share the route and say where the problem occurs.
