  4. Duplicate waypoint doesn't quite duplicate
1 Posts 1 Posters 5 Views 1 Watching
  • Anonymouse
    Anonymouse
    Anonymouse
    Minor issue:
    When a waypoint is duplicated, not all attributes are copied.
    Example:
    On this map there is a via point with red plus hotel icon, at Store Kongensgade 75B which has been named "Apartment" and note added. I click on waypoint 7 and press Duplicate waypoint.
    Result:
    A new waypoint is inserted, offset slightly, at Store Kongensgade 74. It has the same colour and icon. However it has been created as a shaping point and has lost the name and note.
    Expected result:
    When I ask for a via point to be duplicated, I expect every attribute to be duplicated - including name and note.
    (It is also not in the same position as the one it is copied from. I can see why you are offsetting it, but that is not always intuitive. The most common situation when we duplicate a waypoint is to add the start point back into the route - eg on a figure-8 walk around a town with lunch back at the apartment, or a circular drive - and in this case we want everything duplicated including the location. But it's probably visually cleaner to offset it.)
    I think it's cleanest and more intuitive to duplicate all the attributes other than location in any case.
    Anonymouse
    Anonymouse
    • Route Opacity Viewing Existing Routes in Library
    • Guida Libera
    • Move a GPS point on the map
    • Route leads straight to endpoint
      Rolf Engelsman
      Rolf Engelsman
    • Elevation profile: cursor that follows the route on the map
    • Question on Beta access
    • MyRouteApp on the Tracer 9 GT+ Display. Works! :)
