Miscalculations of distance and time between waypoints
Hi, I noticed miscalculation of distance and probably time between waypoints in the route. Here (https://beta.myrouteapp.com/routes/4ca461db-0cef-4781-afcf-6bb775aa7659/nordkap-test) is test route where calculations between waypoints from waypoint #4 onwards are at least suspicious in one case even negative, look at waypoints #8 and #9. Did I miss anything?
I'm not sure what you mean, but for me it looks okay if I use the calculator function.
I see nothing negatives between 8 and 9.
Hi, I dont refer to distance calculator - I refer to waypoints list within the route.
Take a look at total distance in km which is less (6489 km) to waypoint #9 than to waypoint #8 where shows 6898 km. Logical is that waypoint #9 is further away from start point than waypoint #8.
@Matjaz-Valjavec Don't worry about it.
I also reported the same issue a short while ago... and was told to wear glasses
But I agree with you—the zero and the eight are extremely hard to tell apart, at least for me, even with glasses.
Maybe it's possible to adjust the font or the size a little.
Wow, ok that's funny - I need new glasses
. But the question is: why use font with dot in the middle of zero? That is really rare and not practical at all. Hope they will change this unnecessary source of misunderstanding data. -
@corjan-meijerink
It’s really hard to make out on a 2K monitor, even with reading glasses. Even at 125 per cent zoom, it’s still not clear. I had to zoom right in to see it.
Could you make it a bit bigger? I’ve already bought a new pair of glasses. It’s really hard to make out on a 2K monitor, even with reading glasses. Even at 125 per cent zoom, it’s still not clear. I had to zoom right in to see it.
Or use a different font? -
@corjan-meijerink
Or use a different font?I totally agree with @parantapa - I'm sure that you guys understand that your software is used by general public - inevitable is that part of users are not eagle-eyed any more. Hope you will pay some attention to this issue and find a proper solution.
