Can't retrieve club-event "meeting point" / "verzamelpunt" through API
Hi Corjan,
I'm building our MTC website from the ground up. One of the features is to provide an .ics file of the club events so that all events are always updated in the users' calendar.
For ClubApiEvent[] there are these fields:
meetPoint.lat number (Meet-point latitude. The whole object isnullwhen unset.)
meetPoint.lng number (Meet-point longitude.)
meetPoint.label (Meet-point label.)My first question is: is the field "Verzamelpunt" (or "Meeting point" for English version) connected to these API fields?
If so, what does field "Verzamelpunt" / "Meeting point" expect to populate the API fields above.As an example I've created a club event with Meeting Point "Willemstraat 23, Eindhoven".
I've create a debug action and this is the output:Ignore plugin version. This is the Wordpress plugin I've create for the API call to MRA.
{ "plugin": "0.5.6", "uit_lijst": { "id": "18239a43-9d48-44d6-80a1-cadfdfc22a2d", "name": "Dagje Eindhoven", "description": "Een tocht naar Eindhoven", "startsAt": "2026-11-26T23:00:00.000Z", "endsAt": null, "timezone": "Europe/Amsterdam", "status": "upcoming", "meetPoint": null, "capacity": null, "goingCount": 0, "interestedCount": 0, "imageUrl": null, "routeCount": 0, "dayCount": 0, "singleDay": true, "webUrl": "https://beta.myrouteapp.com/events/18239a43-9d48-44d6-80a1-cadfdfc22a2d", "calendarUrl": "https://beta.myrouteapp.com/events/18239a43-9d48-44d6-80a1-cadfdfc22a2d/calendar.ics" }, "uit_detail": { "data": { "id": "18239a43-9d48-44d6-80a1-cadfdfc22a2d", "name": "Dagje Eindhoven", "description": "Een tocht naar Eindhoven", "startsAt": "2026-11-26T23:00:00.000Z", "endsAt": null, "timezone": "Europe/Amsterdam", "status": "upcoming", "meetPoint": null, "capacity": null, "goingCount": 0, "interestedCount": 0, "imageUrl": null, "routeCount": 0, "dayCount": 0, "singleDay": true, "webUrl": "https://beta.myrouteapp.com/events/18239a43-9d48-44d6-80a1-cadfdfc22a2d", "calendarUrl": "https://beta.myrouteapp.com/events/18239a43-9d48-44d6-80a1-cadfdfc22a2d/calendar.ics", "days": [], "highlight": null }, "meta": { "attribution": { "text": "Powered by MyRoute-app", "url": "https://beta.myrouteapp.com" }, "generatedAt": "2026-11-19T23:51:32.088Z", "version": 1 } }, "agenda_locatie": [] } -
Thanks for the clear report, and great to see you building on the API! You found a bug.
Yes, the "Verzamelpunt" / "Meeting point" field is the API's meetPoint. The website stores it as text only, without coordinates, and the API only returned meetPoint when coordinates were present. That's why you always got null.
That's fixed, and it will be on beta with the next update. Your event will then return:
"meetPoint": { "label": "Willemstraat 23, Eindhoven", "lat": null, "lng": null }
For your .ics, use meetPoint.label as the LOCATION. Do allow for lat and lng being null: for events made on the website they usually are. meetPoint itself is only null when no meeting point was filled in. The field docs on /developers now say this too.
Let me know once you see it come through, or if anything else comes up. Good luck with the new MTC site!
I am really curious about all the API feedback in general. I’ve reviewed and tested it all fro a functional perspective but I wasn’t actually using it
So please do create new topics about other issues / missing features regarding the API. -
Hi Corjan,
Thanks for the reply. I've changed the code on my side and I'll wait for the MRA update to come available. I'll update this topic when I've tested this again.
When I have more API-related questions/issue's I'll let you know!
Thanks for the quick-fix
Gr
Bart
The API change is live. Let me know if it works as expected for your and if you have more feedback
Hi Corjan,
Yes, the location is now visible in the events on the website.
They also appear in the ics-calendar feed (I did some extra work for showing the location on a map).Thanks for the support and update!
Geweldig
