MyRoute-App does not work on Caretta
@Corjan-Meijerink: With Claude’s help, I analysed the potential error that occurs when launching navigation in the MyRoute app on my Caretta, based on the log files. Here are two excerpts:
GnssManager: registration 10065/com.cloudmax.myrouteapp/65A63BD4 removed GnssManager: registration 10065/com.cloudmax.myrouteapp/706B0882 removed GnssManager: registration 10065/com.cloudmax.myrouteapp/FB989726 removed GnssManager: registration 10065/com.cloudmax.myrouteapp/65A63BD4 removed GnssManager: registration 10065/com.cloudmax.myrouteapp/706B0882 removed GnssManager: registration 10065/com.cloudmax.myrouteapp/FB989726 removed
This means: The app registers with the GPS system but is immediately logged out again – precisely at the moment when navigation should start. This is most likely the cause of the error.
PackageConfigPersister: App-specific configuration not found for packageName: com.cloudmax.myrouteapp
This suggests that a device-specific configuration for the app is missing.
According to Claude, the result is as follows:
• Problem: GnssManager registrations are removed immediately after navigation starts
• Logcat entries: GnssManager: registration com.cloudmax.myrouteapp removed
• Also: PackageConfigPersister: App-specific configuration not found
• Other navigation apps (Google Maps, TomTom, DMD2, Locusmaps) work perfectly
• App was freshly installed from the Play Store, all permissionsPerhaps this specific technical information will help pinpoint the problem, and hopefully it can be resolved quickly in a future app update.
@ Corjan: You’d already mentioned the GPS connection. I haven’t made any changes to that on my Caretta. Perhaps this specific technical information will help pinpoint the problem, and hopefully it can be resolved quickly in a future app update.
I send this information to Carpe Iter, too.
Cheers
Markus -
Cheers
Markus@Markus-Hellenthal-Dr. Interesting.
Our apps does exactly the same as it does on every Android device and I don’t see these issues on our test Caretta
Regarding GNSS, they do manage that on hardware level and even mentioned changes in the latest OS update: https://carpe-iter.com/caretta-initial-os-update/
A little kick. I am in de proces of buying a different bike. This means also buying a different navigation device. The Caretta is one of the options on my shortlist.
What is the current situation of MRA of the Caretta. Is it just as reliable as MRA on other devices or has the combination Caretta and MRA still some quirks. -
Cheers
Markus@Dr.-Markus-Hellenthal Hi, have you sorted this issue yet?
I am having the same problem as you with my MRA/Caretta combination (all software up to date, obviously). The app is very slow to load and to load routes. Navigation is severely impaired by the GPS tracking often being 50-100m behind. It just feels "wrong". By comparison, I used Google maps today and the GPS tracking was perfect.
Many thanks. -
What setting do you for GPS accuracy?
Read some info that MRA, but not only MRA, some issues has with the highest setting. -
Many thanks.@iain.gardengmail.com sagte:
Many thanks.Hi,
No, the problem has not been solved. I have reset my Caretta twice, no improvement. I have the impression that there seems to be a hardware - software communication issue. My Caretta, i. e. NGH as well as MRA need up to one hour to get a satellite connection and looses it from time to time. Strangely, Google Maps works without any issue.
Cheers
Markus -
Hi everyone. I'm new to the forum and I greet you all warmly. I also have the problem of MRA being slow on Caretta. I bought it a week ago, it's fully updated, everything works fine except MRA, which is very slow. I set GPS Tune (preinstalled on Caretta) to 1Hz. Magically, MRA works fine. If I set GPS Tune to 5Hz, it slows down; if I set it to 10Hz, it freezes. So it seems that the problem is related to this. It's hard to say whether it's an internal problem with MRA or the interaction between Caretta and MRA. For now, I've solved it by setting it to 1Hz when I use MRA and back to 10Hz for the other navigation apps.
@FulZan A very useful contribution. Thanks.
The refresh speed of the GPS receiver is indeed the main issue for the Caretta with MRA. When set to 10 Hz some other apps could have some issues too.
But who' s to blame. MRA?, Carpe Iter? i don't know. But MRA seems heavily affected by this problem compared to other apps.
For now i'll keep my Android Auto screen.
Just letting you know I have prepared a 10Hz fix in version 6.0.1. If that update is available, expect in a week or two, can you let me know if it works well?
