  4. Move pop up
Move pop up
2 Posts 2 Posters 20 Views 2 Watching
  • Albert van den Elsen
    wrote last edited by Albert van den Elsen
    When you try to select routes or folders in 'Routes and Tracklogs', a pop-up appears showing the number of selected items. This pop-up window covers the routes at the bottom, preventing you from selecting them. Could the pop-up be moved to the right so that all folders and routes remain visible and you can select them all?
    Example:
    iPhone 15,
    Garmin Zumo XT3
    Carpuride W702 Pro
    Sena 20S EVO headset
    Harley Davidson Road King M8
    • Rob Verhoeff
      Have you tried scrolling through the list? Although the pop-up is fixed at the bottom of the screen, you can still scroll through the list without any problems and select all the routes and/or tracklogs. By moving the pop-up to the map, as you suggest, it would get in the way when you want to see how routes overlap or which routes you have ridden in a particular area. I think its current position is just fine.
        3.1k
      • Navigating on NEX
      • Spoken notes are truncated
      • Automatic optimization of an entire route to find the shortest route in terms of time or distance.
        Chris 4p
        Chris 4p
      • v6, tankstation
      • Shaping points placement for legacy routes - snap to road
      • Website update - Best order, daylight on your ride, edit several waypoints at once and more
        Anonymouse
        Anonymouse
