  4. Map lock
Map lock
17 Posts 5 Posters 107 Views 2 Watching
  • tfdahazellgmail.com
    tfdahazellgmail.com
    tfdahazellgmail.com
    Where has the map lock gone on the planner? I'm sure there was a little icon there the other day? 🧐🤔
    • tfdahazellgmail.com tfdahazellgmail.com
      Right bottom corner...
      tfdahazellgmail.com 1 Reply Last reply
        tfdahazellgmail.com
        tfdahazellgmail.com
        tfdahazellgmail.com
        @Rob-Verhoeff nope it's disappeared for my Chromebook 😔
        Marinus van Deudekom Rob Verhoeff 2 Replies Last reply
          @tfdahazellgmail.com map lock is only useful in a mobile device and NN
            @tfdahazellgmail.com A Chromebook naturally has its own "ecosystem". I can only test this in the Google Chrome app on my MacBook. The padlock icon for locking a route is available there.
              tfdahazellgmail.com
              tfdahazellgmail.com
              tfdahazellgmail.com
              wrote last edited by tfdahazellgmail.com
              @Marinus-van-Deudekom please don't tell me what I should find useful or not. It was there previously and it isn't there now
                tfdahazellgmail.com
                tfdahazellgmail.com
                tfdahazellgmail.com
                @Rob-Verhoeff It was there the other day and it is not there now
                  tfdahazellgmail.com
                  tfdahazellgmail.com
                  I should probably clarify in case there's some confusion. It was the route lock button so you didn't put a extra waypoint in if you clicked a screen by mistake
                    tfdahazellgmail.com
                    tfdahazellgmail.com
                    Just had another look and it looks like the sensitivity is perhaps been turned down so it's not as easy to click and make another route point by mistake as it was once before
                    • Marinus van Deudekom
                      OK I misunderstood your question. Locking a route to prevent accidently changing a route is still possible. Click on the 3 dots when you select a route and you"ll find it there
                        I most certainly don't want to tell you what is usefull.
                          So, if I create a new route and want to thoroughly check it before finalizing, I first have to save it, then lock it in the library, and only then open it for that final review?
                          That makes me understand the request for a better placement of the lock icon even better now. 😉
                          • TorqueRider TorqueRider
                            @TorqueRider That is possible but as long as your working on a route I wouldn't lock it at all. Normaly I don't lock my routes at all. Only my Xpert routes are locked for obvious reasons
                            • TorqueRider
                              @marinus-van-deudekom
                              There are people who might not want to work exactly the way you do, right?
                              For instance, I use this feature because I lack good dexterity in my fingers. Others might use it for different reasons.
                              I was very pleased to see that it is still included in the legacy environment.
                                @TorqueRider For me it's all okay everybody can work the way they want. Just stating my workflow, nothing more. Creating routes is a process I do mainly on a PC while others use a phone or tablet. Looking at my big hands I save myself from anger doing a complicated rout on a tablet of phone. That's my handicap and I know myself very well 🙂
                                  tfdahazellgmail.com
                                  tfdahazellgmail.com
                                  tfdahazellgmail.com
                                  Well you did. This is a forum for suggestions which get hopefully picked up by the developers. Having a route expert come along and say well actually it's not a problem. Isn't helping anyone
                                  For the average or casual user MRA can be quite complicated which I found but I stuck with it rather than going back to calimoto Which is more user-friendly, but with these suggestions it is getting more user-friendly. Therefore, they'll be more customers for MRA
                                  Something simple, as having a lock icon rather than having to go into a 3 dot menu and find it Just so you don't mess up your route and add another waypoint because you pressed the button by mistake does make things easier, the same as when you wasn't happy with my suggestion of removing the heat map of the experts and instead having the lines which has been changed and is now much easier to use and easier to plan from which is the whole point of MRA
                                  I've paid my money to be able to contribute to this app because I do believe in it but I'm not going to suggest any more things that an average user might like if I constantly suggest and get told I'm wrong. Otherwise I've just wasted my money and my time
                                  • Andy Nicholson
                                    Andy Nicholson
                                    Andy Nicholson
                                    wrote last edited by Andy Nicholson
                                    I find the route lock button very useful (firefox, pc) - without it I frequently accidentality add waypoints.
                                    Today I discovered that while I as a route owner have and can use the option, collaborators on the same route do not / cannot.
                                    Any chance a "don't accidentality add waypoints" toggle could be enabled for collaborators?
                                    tfdahazellgmail.com
                                    tfdahazellgmail.com
                                    Andy Nicholson
                                    Andy Nicholson
                                    • Heatmap menu: Display traveled routes
                                    • Route exporteren uit beta
                                      Johan 5q
                                      Johan 5q
                                    • POI Removal Method from the Routing Menu
                                    • SilverFox Controller C2
                                      Hans Lamers
                                      Hans Lamers
                                    • Beta abonnement
                                      BMW1300GSA
                                      BMW1300GSA
                                    • "Please verify your email" display
                                    • Layers menu: option to permanently display Favorite labels
