  4. F024 Route selection – copying within MRA is still too cumbersome
3 Posts 2 Posters 20 Views 2 Watching
    Within the MRA WebPlanner, copying more than one carefully planned route—while retaining all the original MRA data—is currently quite cumbersome.
    • Copying a single route requires a workaround: you must first open it in the Planner and then save it as a copy.
    • For multiple routes, the only option is to download them—a process that requires careful attention to the file format. Downloading more than one route always results in a ZIP file, which must then be unzipped before the files can be re-uploaded. When doing so, it is essential to select the new format: MyRoute-App (.mra "Complete Roundtrip").
    Suggestion: Add an option to copy routes directly into your own library within MRA.
    Data sources: Clubs or friends
    • Enable multi-selection via the checkboxes on the left, and provide an option to copy the selected routes directly into your own library or a subfolder within your personal routes.
    New field: "Copy to Library," located to the right of the "Download" button.
    iPad 9. G iOS 27.2.0/iPhone 16e iOS 27.2.0/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
      Thanks for the clear suggestion and the screenshot. We've built it, and it will be on the beta with the next update.
      When you tick routes in a club's, an event's or a friend's library, a "Copy to library" button now appears next to Download. You choose a folder in your own library, and the routes are copied straight in with all their waypoints, POIs and settings. You can tick whole folders too: their subfolders and routes come along. No ZIP, no unzipping and no file format to choose.
      For a single route there's also "Save a copy" in the ⋯ menu of a club route now, so you don't have to open it in the planner first.
      Let us know how it works for you!
        Hey, thanks for that! I’ll test it once it becomes available to us. Thanks a lot for the quick support!!
        • Map lock
        • Route exporteren uit beta
        • V6 - Track Navigation
        • Beta abonnement
        • How to add a new favorite using my current location?
