<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[F024 Route selection – copying within MRA is still too cumbersome]]></title><description><![CDATA[<p dir="auto">Within the MRA WebPlanner, copying more than one carefully planned route—while retaining all the original MRA data—is currently quite cumbersome.</p>
<ul>
<li>
<p dir="auto">Copying a single route requires a workaround: you must first open it in the Planner and then save it as a copy.</p>
</li>
<li>
<p dir="auto">For multiple routes, the only option is to download them—a process that requires careful attention to the file format. Downloading more than one route always results in a ZIP file, which must then be unzipped before the files can be re-uploaded. When doing so, it is essential to select the <strong>new format: MyRoute-App (.mra "Complete Roundtrip")</strong>.</p>
</li>
</ul>
<p dir="auto"><strong>Suggestion: Add an option to copy routes directly into your own library within MRA.</strong></p>
<p dir="auto"><strong>Data sources: Clubs or friends</strong></p>
<ul>
<li>Enable multi-selection via the checkboxes on the left, and provide an option to copy the selected routes directly into your own library or a subfolder within your personal routes.</li>
</ul>
<p dir="auto"><strong>New field: "Copy to Library," located to the right of the "Download" button.</strong></p>
<p dir="auto"><img src="/assets/uploads/files/1794215871947-screenshot-2026-11-09-101629.png" alt="Screenshot 2026-11-09 101629.png" class=" img-fluid img-markdown" width="1500" height="1084" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/12488/f024-route-selection-copying-within-mra-is-still-too-cumbersome</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 11:38:21 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12488.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Nov 2026 09:22:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to F024 Route selection – copying within MRA is still too cumbersome on Mon, 09 Nov 2026 10:50:06 GMT]]></title><description><![CDATA[<p dir="auto">Hey, thanks for that! I’ll test it once it becomes available to us. Thanks a lot for the quick support!!</p>
]]></description><link>https://forum.myrouteapp.com/post/88513</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88513</guid><dc:creator><![CDATA[Hubert Thoring]]></dc:creator><pubDate>Mon, 09 Nov 2026 10:50:06 GMT</pubDate></item><item><title><![CDATA[Reply to F024 Route selection – copying within MRA is still too cumbersome on Mon, 09 Nov 2026 10:08:34 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the clear suggestion and the screenshot. We've built it, and it will be on the beta with the next update.</p>
<p dir="auto">When you tick routes in a club's, an event's or a friend's library, a "Copy to library" button now appears next to Download. You choose a folder in your own library, and the routes are copied straight in with all their waypoints, POIs and settings. You can tick whole folders too: their subfolders and routes come along. No ZIP, no unzipping and no file format to choose.</p>
<p dir="auto">For a single route there's also "Save a copy" in the ⋯ menu of a club route now, so you don't have to open it in the planner first.</p>
<p dir="auto">Let us know how it works for you!</p>
]]></description><link>https://forum.myrouteapp.com/post/88499</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88499</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Mon, 09 Nov 2026 10:08:34 GMT</pubDate></item></channel></rss>
