  4. Via Points not announced as I drive over them ?
5 Posts 2 Posters 234 Views 1 Watching
  • David 38
    David 38
    David 38
    Are there any known situations where Via Points should not be announced ? Some/most of my Via Points ARE announced when I drover over them, but not all.
    I have not converted to 6.0 yet.
    David 38 1 Reply Last reply
    • David 38 David 38
      David 38
      David 38
      David 38
      I had a hunch, so did some testing and seem to have found a pattern/cause .........
      If I skip via point n, when I've gotten a little to close to reaching via point n + 1 (but have not yet reached n + 1), I do NOT get an announcement when I reach n + 1.
      But if I had skipped n sooner, then I get the announcement when I reach n +1.
      Has anyone else noticed this ?
      I would also welcome feedback on whether my Audio settings could be contributing to this. Here are my settings:
      Volume - mid-point
      Voice prompts - ON
      Audio delay - 2.0 (ie max)
      Number of voice prompts per instruction - 4
      Waypoint notifications - ALL
      Speed warnings - Camera only
      Would adjusting the delay or number of voice prompts potentially help ?
      Thanks.
      • ErikMatthezing
        ErikMatthezing
        ErikMatthezing
        @david-38 Could it be that you have via points like that just before a turn or roundabout? Sometimes they nearly coincide with an instruction from MRA, and then the via point isn't spoken.
        • ErikMatthezing ErikMatthezing
          David 38
          David 38
          David 38
          @ErikMatthezing
          Here is a pic of my route:
          I intentionally dont make the turn to via point 3, and if I skip vp 3 as I get closer to vp 4, vp 4 is not announced.
          I ended up upgrading to 6.0, changed voice prompts from 4 to 2, and changed audio delay from 2.0 to 0.9, and now it seems to announce vp 4 even if I perform the skip vp 3 when I'm close to vp 4. Not sure if 6.0 fixed this or if the settings changes fixed it.
          But seems to be working ........ but will keep an eye on this.
          • ErikMatthezing
            ErikMatthezing
            ErikMatthezing
            @david-38
            That is indeed strange; I wouldn't know offhand why this is happening.
            What I do notice is that you are using Via Points everywhere. The advice is to only use Via Points at the start and stop of the route, or at points where you really want to stop. You see, you have to visit Via Points within a route, otherwise the app sends you back.
            Weren't you constantly being sent back on the route after not visiting route point 3?
            ErikMatthezing
            ErikMatthezing
            David 38
            David 38
              Jeroen ekkel c
              Jeroen ekkel c
            • Xpert overlay not clear
            • Kaart niet zichtbaar
            • Trains like Ferries?
              JP d
              JP d
              Hanza 0
              Hanza 0
            • Vermijdingsopties is wat verwarrend
              Eric Bovelander
              Eric Bovelander
