  4. Route planner doesn't want to follow the road
4 Posts 3 Posters 93 Views 1 Watching
  • Alexandre Marcel
    Alexandre Marcel
    Alexandre Marcel
    I'm just playing with the new web, and I first tried to plan a route, the one I know perfectly well, and I just found a problem, surely is some settings that I don't have quite right, the route planner keeps taking me out from the main road ( in the green circle), even when I try to put my waypoints on the dead centre of the road, moves them to where he thinks there's a road, in fact waypoint 4 is a street.
    Maybe it's not a problem of settings maybe is a problem of using the wrong map.
    The village is Ascara in the north of Spain, (Aragonese Pyrenees) in case you want to try.
    Thank you in advanced, and great job.
    • Alexandre Marcel Alexandre Marcel
      @Alexandre-Marcel, This is because of a discrepancy between the MapTiler (visual) map and the HERE (or TomTom) calculation engine. These kind of discrepancies were also visible in the old planner, when you used a different overlay on a different base map. The new planner uses MapTiler maps always, regardless of the calculation engine, so these things will happen where there are larger differences between them.
      • Angelo Greco
        Angelo Greco
        Angelo Greco
        On the previous version we were told to always check that the waypoints were exactly on the road. Is this no longer a requirement?
        Is it not possible to set HERE as the default map for planning?
        Thanks
        • MotoCon
          Yes, but in the new planner the road is dictated by the calculation engine, not by the maptiler maps. Besides, routepoints are automatically snapped to the route line now. As far as I know a new route wil use the last used routing engine.
          Alexandre Marcel
          Alexandre Marcel
          Angelo Greco
          Angelo Greco
          • Online map settings
          • MRA-pictogram
