Map colours and side roads
Any advanced motorcycle training will tell you not to overtake on approach to a junction or side road. I would like to request that more of the map colour options show side roads clearer. In the original navigation app only the "Roads only" map makes side roads easy to see (they are yellow and not white as in all the other map layers).
This is a safety feature enhancement
Thanks
Thanks
@BikeRNick Every good instructor teaches you to read the road. That way, you don't need to look at the map to spot a side road. Spend less time looking at your navigation device and more time watching the road. Now that's a real improvement in road safety!
@Rob-Verhoeff said:
Every good instructor teaches you to read the road.Thatβs absolutely right. The sat-nav should only be a tool to help you find the right direction! If you pay close attention to the road, you can βreadβ it.
And if not, then perhaps you should take a few more lessons! In the Netherlands there are specialised courses for. -
While I agree with @rob-verhoeff (only overtake when you see there is no sideroad in reality instead of in screen), there is more at play here. When your navigation tells to go right at a junction, it is an easy error to go right one junction too early if it is close by and you cannot see it on screen. Therefore I think there is value in having the map resemble reality.
In the beta app there are new map colors available that in my view are a step in the right direction though. Especially "Stanley" is my new favorite.
@MotoCon The next turn instruction in the top left has a clear distance visible so this should be enough information to determine if it is the left turn in front of you or the next one.
Not always that obvious. "Over 300 meter left" is that the first or second road. The distance between the two roads is approx. 20 meter. In the fine maze of roads in The Netherland this situation is more common than you think. Even in rural area's this is not that strange.
@M.-Schrijver Stanley is in the latest beta version. Untill mr Google had found some time you'll have to wait a bit longer.
With your input, this post could be even better π
