  4. Problem with HERE, getting the route correct ??
5 Posts 3 Posters 104 Views 1 Watching
  • BertM
    wrote last edited by BertM
    below a link to a route.
    Trying to get a old route into MRA.
    I try to get the route around point 24 going down, but HERE refuses to do so, TT and OSM route the way I planned.( going down and up again.)
    https://www.myrouteapp.com/nl/social/route/14639730?mode=share
    anybody got an idea why?
    Peter Zehentreiter Brian McG 2 Replies Last reply
    • BertM BertM
      @BertM said:I'm not quite sure what exactly you want.
      Is this what you're looking for?
      https://www.myrouteapp.com/de/social/route/14657125?mode=share
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
      • BertM BertM
        @BertM the data for the Here map is different on the loop to the north of Marienhagen
        the Here map says it is not possible to pass
        this appears to be because the Here map has a small section of this road marked as "Local Access Only"
        maybe the road priority has changed & Here is correct & OSM & TomTom are wrong
        the sure way to know is to physically investigate
        BertM 1 Reply Last reply
        • Brian McG Brian McG
          @brian-mcg What card did you use to find this ?
          It was 10 Years ago I did that trip... maybe we do it again and check 🙂
          Thank you for the help, got me busy for some time..
          Brian McG 1 Reply Last reply
          • BertM BertM
            @BertM the first picture is MRA just using the 3 different routing calculators, Here, TomTom & OSM
            by moving the 2 points closer together I was able to isolate / narrow down where the Here card was failing
            then looking on the Here Map Creator site I was able to find the local access restriction
            the reason that the route is working for you in one direction & not the other is you were lucky / unlucky that you have placed point 33 exactly on the restricted road so the routing passes through
            if you move point 22 so it is next to point 33 then the route will pass both ways
            • Route wordt afgesneden
              Wim Hompes
              Wim Hompes
            • Problem with HERE, getting the route correct ??
            • Map blurred when editing POIs
            • Maps Michelin
              Jacob Waterweg
              Jacob Waterweg
            • App failed to start; reinstall locked me out!
              Anonymouse
              Anonymouse
            • OSM Routing with MRA
            • Weer een positieve ervaring!
