  4. A20 Edit tracklog – adjust the start or end point, and clean up zig-zag patterns.
4 Posts 4 Posters 10 Views 3 Watching
    I recorded a tracklog here (on 25-07-2026) and have now opened it in the new web planner. I would like the ability to clean up the recording after the fact—for instance, in cases where the device wasn't set to "pause," meaning everything (including unwanted movement) was captured.
    • Specifically, I would like to be able to edit the tracklog along its path—for example, to smooth out "zig-zag" patterns or remove specific, disruptive sections of the route.
    • I would also like to be able to shift the starting point—useful if the navigation device was started while still inside a house or hotel, or while I was still lingering by the bike.
    • Similarly, I would like to be able to shift the end point—useful if the navigation device continued recording after I had already arrived at a house or hotel.
    Nick Carthew Rob Verhoeff 2 Replies Last reply
      @Hubert-Thoring A tracklog is a true record of your journey, even if it was possible I don’t think a tracklog should be made editable. If you want to retain your privacy you can pause or stop the tracking before you reach your destination.
        @Hubert-Thoring @corjan-meijerink would say: TRACKLOG-DISCIPLINE.... 😉
          Hi, the only possibility is with manual work. Export the gpx, edit with https://www.beavertrack.de/ (delete unused WP), save it and upload back to MRA.
          Add pictures manually.
          • MRA Studio export speed
          • MRA 6.0.0 (526) - Offline Calculation Problem
          • Map colours and side roads
          • Routeberekening zonder invloed van actuele verkeerssituaties en wegafsluitingen
          • route bug
          • geeft routepunt niet weer
