  4. MRA 6.0.0 515 – Removal of the "Navigate routes as tracks" option and problems with outdated road closures in HERE
10 Posts 5 Posters 54 Views 4 Watching
  • Reinhard Punz
    Reinhard Punz
    Reinhard Punz
    In my region (southwestern Lower Austria), HERE map data has recently been frequently showing outdated road closures. Sometimes roads remain marked as closed for months, even years, even though they have reopened.
    Navigate as a track was a useful solution because it allowed me to follow my originally planned route without taking unnecessary detours due to inaccurate road closure information in HERE.
    In version 6.0.0 515, I can no longer find this option.
    I have found a temporary workaround: I activate the "Show original route" option in the navigation app and follow it manually when I am certain that the road is actually open. The downside of this solution is that MRA constantly recalculates the route and provides navigation instructions, which can be quite confusing.
    And this solution only works as long as the web planner has up-to-date information and allows the desired route in the first place. If the web planner also accesses outdated road closures, I'm currently unaware of any way to ignore incorrect road closures.
    My questions for the developers:
    In version 6.0.0, is there a way to navigate a planned route independently of HERE's road closure information, as was previously possible with track navigation?
    If not, could you envision introducing a feature that allows users to deliberately disable individual road closures (i.e., the opposite of the existing option to create custom road closures)? Of course, this carries the risk of encountering a closed road – but the responsibility for that would lie with the user.
    • Reinhard Punz Reinhard Punz
      wrote last edited by Stefan Hummelink
      Edit: Oops, my message below is valid only for 6.0.0. - 526, not for 515 yet. Sorry! 😅
      You might find what you seek by using the "Offroad" navigation type which is also offered with a button next to the "Navigate" button.
      In offroad "mode" so to speak, you do not get any recalculations and the app tries to keep you on the route as good as possible. When diverging from the route, you see a "xxx distance from route" notification instead of a instruction and recalculations will NOT be performed.
      Please note that the engine that does this, tries to approach the original route as good as it can, but it may mean that not every "maneuver" is translated into a explicit instruction.
      Simply try it out. 😉
      LE DIZES Freddy Reinhard Punz 2 Replies Last reply
        wrote last edited by Jörgen
        @stefan-hummelink I think this button/function is not yet available in version 515.
        • LE DIZES Freddy
          LE DIZES Freddy
          LE DIZES Freddy
          Off is not on 515
            LE DIZES Freddy
            LE DIZES Freddy
            LE DIZES Freddy
            @Stefan-Hummelink sur la version 515 , il n'y a pas "OffRoad"
            • Bouke Ent
              i look at android 515 and option drive route as track is not any more in menu.
                @Jörgen said:
                not
                Nope. See my edit note in the post.😉
                  Off is not on 515
                  @LE-DIZES-Freddy said:
                  not
                  Nope. See me edit in my post 😅
                    n'y a pas
                    Yep. See my edit note in my post.😅
                      Reinhard Punz
                      Reinhard Punz
                      Reinhard Punz
                      @stefan-hummelink: Thank you for your response – I will look forward to version 526 and test it as soon as it’s available.
                      Reinhard Punz
                      Reinhard Punz
                      LE DIZES Freddy
                      LE DIZES Freddy
                      • Beta Navigation V.6
                      • MRA 6.0.0 515 – Removal of the "Navigate routes as tracks" option and problems with outdated road closures in HERE
                        Reinhard Punz
                        Reinhard Punz
                      • Route overlay
                      • Suggestie voor notitie teksten tijdens rijden
                        Albert van den Elsen
                      • Versie 6 van Navigation Next app
                      • wat is het verschil tussen het initial scherm en Free Ride in Android Auto
                      • Machtiging tot Fysieke Activiteiten
