  3. Off road turns into endless "proceed to XXX"
13 Posts 5 Posters 2.1k Views 1 Watching
  • Greenhamundefined Offline
    Greenham
    Uggh,
    I put a lot of work into a route. Carefully placing s=shaping points (zooming in and placing on the rd) making sure I'm not placing a point at an intersection. I then compare it (I have Gold) to Tom Tom and Open. I then use Google maps and they are all fairly close.
    Yet when I ride I inevitable get a a message that says I am going to "leave the rd" then I pass that point and it then says "proceed to XXXX" (The road I'm on).. all other helpful navigation such as next turn and distance stop. it just says proceed to XXXX rd. I can use the graphic on screen to navigate for some number of miles and then it will start navigating again.
    This is really aggravating. Especially after spending so much time trying to make a good route.
    I use a Zumo 396 (I just ordered the XT)
    Any suggestions what I am doing wrong
    PAD 0undefined 1 Reply Last reply
    • Greenhamundefined Greenham
      Uggh,
      PAD 0undefined Offline
      PAD 0
      @Greenham I think it might be helpful to make your route public and share a link here. Certainly, I find it difficult to make any suggestions. Just one question, concerning your sat nav, and this only for clarity really... I believe (but could be wrong) that the 396 is compatible with .gpx 1.1 files. Is that what you used to transfer from MRA to the device?
      Drabslabundefined Greenhamundefined 2 Replies Last reply
      • PAD 0undefined PAD 0
        Drabslabundefined Offline
        @PAD-0 yes, show us the route so that we can have a look
          Greenham
          @PAD-0 That is correct. I use the gpx 1.1 on exporting. Below is the link. The problem occurs between point 7 - 9. I rode the route again today. Same problem. When I opened the (proceed to Hwy 96) direction on the screen, It first said it 5,000 miles, then it cleared and the rest of the route proceeded perfectly..
          https://www.myrouteapp.com/en/social/route/2496687?mode=share
            PAD 0
            @Greenham The only thing I noticed on a cursory glance is that WP8 & WP9 aren’t well located on the road centre line. Looking at street view, this isn’t a wide road and the location doesn’t seem absurdly wide, but nonetheless I‘d be inclined to go through the route, zoom in as far as possible on every waypoint and centre every one exactly on that centre line.
              Hi Greenham,
              Which file do you use in your Zumo? The route or the Track?
              For the older Zumo models, it is best to use the Track.
              Go to tracks, click on the track of the route you want to drive, then click on the key in the upper left corner.
              Choose to make visible,
              Choose a color (black or white for the best contrast)
              Choose, convert to travel
              Choose from start to finish
              Zumo is going to count ......
              When he has finished calculating, you go to the travel planner and the calculated route based on your Track is included in your travels.
              Turn the recalculation OFF!
              You now have only 2 Hard Route Points, namely start and finish.
              If you deviate from the route, you must drive back to the route in sight (Track has made you visible)
              With the XT you can use the route.
              Greenhamundefined 1 Reply Last reply
                Hi Greenham,
                Greenham
                @Hans-van-de-Ven-MRA-Master THanks Hans, Yes I use your documented process as you outlined in your comment.
                I will take Pad-O advice and check the placement of my shaping points.
                I did just buy the XT... what would e different with it when exporting from MRA tothe XT?
                Steve Lynchundefined Greenhamundefined Hans van de Ven MR.MRAundefined 3 Replies Last reply
                  Steve Lynchundefined Offline
                  Steve Lynch
                  @Greenham
                  My personal choice for the XT is to transfer the Beta Zumo XT GPX1.1 using the Garmin Drive App. I generally use an iPad Pro for this.
                  This creates the route automatically in the Trip Planner App on the XT.
                  I only use Shaping Points and I make a point of adding at least 1 shaping point on every road I want to travel on regardless of how long the route is.
                  This works for me, it has never recalculated on me and when I get a road closure it will prompt a couple of U-Turns which I ignore and it will automatically find its way back to the shaping points I plotted in MRA.
                  I don’t find that I need any track visible to get me back on my route.
                  When I do go off road, UK Green Lanes (Byways Open to All Traffic) then tracks are perfect.
                  I plot them in the OS Maps App and transfer directly to the Garmin via a PC.
                  You do not get any notifications or turns you simply follow the Track visually.
                  Below is Salisbury Plains with 74 individual Green Lanes placed in a Collection to make them all visible on the map at once.
                    Greenham
                    @Greenham I reran the route today and stopped to take the pics as each stage of the malfunction. 1) Said Leave the Road. 2) Ride to Hwy 96. 3) When I opened that message you can see the GPS thinks the next shaping point is 5500 miles away
                    ![alt text](Inked20210716_102447_!_LIa1.jpg image url)Inked_2.jpg Inked20210716_102806_LI_1b.jpg
                      @Greenham
                      That you can use the created route, with via-points
                      • PAD 0undefined Offline
                        PAD 0
                        I don't understand the quite frequently repeated recommendation for older Garmin devices that a track be used. I have never done so, having only exported routes into my Zumo 390. Every one has worked perfectly well. Using a track on the road seems a very limiting approach to me.
                        In the case of my 390, I choose the 'old Garmin' .gpx file, however the 396 is still a current model in Garmin's motorcycle line up and I believe it supports .gpx 1.1 files.
                        Can someone enlighten me as to why this 'track recommendation' exists, please?
                          @PAD-0
                          With the older zumos, you get a so-called "Direct route" in your system, which you have to let the system recalculate, and so can deviate from your planned route
                            @PAD-0
                            PAD 0
                            @Hans-van-de-Ven-MRA-Master That hasn’t been my experience at all, but maybe I just manage to put in all the right waypoints in all the right places or something (so more Andrew Preview than Eric Morcambe🤪)?
                            Only if I use a .gpx 1.1 file do I get straight lines - can I take it that is what is meant by ‘direct route’? I do appreciate that, in such circumstances, where recalculation is required to make lines follow roads, deviation from the intended route is highly likely. Using .gpx 1.0… perfect routes on the 390 every time. I used such a route today, in fact, running concurrently with Navigation (Zūmo bluetooth off to avoid two sets of voice instructions!). Identical renditions.
                            Greenhamundefined
                            Greenham
                            Drabslabundefined
                            Steve Lynch
                            PAD 0undefined
                            PAD 0
                            • Rondreis Schotland en VK
                              Alida Veenstraundefined
                              Alida Veenstra
                            • Following a track
                              RetiredWingManundefined
                            • Fullscreen Switch No function
                            • unable to dismiss "Resume Navigation?" overlay with remote
                              Andre Trudeauundefined
                              Andre Trudeau
                            • Export waypoints to Google Maps on mobile
                            • MRA 5.1.0 (462) Turn the card to stop and continue driving after a break
                            • Zoom Out in north Up view
                              Lluis Arasanzundefined
                            • Android 9: no tracklogs
                              Gijs Jonkerundefined
                              Gijs Jonker
