  4. LAN004 - Route Import filetypes
13 Posts 4 Posters 41 Views 4 Watching
  • Lluis Arasanz
    I tried to import a route, and see all normal file types, plus “.mra”.
    Thinking format is the same that export as “MyRoute-App (.mra, full route)”, I tried to export and import.
    Export as MyRoute-app generates a .json;
    Import does not recognize neither .json nor .mra file types.
    Only the two GPX I have are detected.
    Missed something?
    • BMW F750GS
    • Lluis Arasanz Lluis Arasanz
      Missed something?
      @Lluis-Arasanz The .mra format is specifically designed for people who want to back up their library themselves. It allows you to export all the details you have recorded in your routes. You can export all your routes in one go. MRA packages them into a ZIP file, including your folder structure.
      Stefan Hummelink Lluis Arasanz 2 Replies Last reply
        wrote last edited by Stefan Hummelink
        @Rob-Verhoeff Obviously,yes, but what purpose does backing up files into a proprietary format other than gpx, serve when those files themselves cannot be read back by the platform they have been exported from. 😂
        This must be one of those minor thingies Corjan solves in a jiffy...😀
          @Rob-Verhoeff
          I suppose you mean this export format, don’t you?
          This generates a .json file, not an .mra
          Import does not recognize neither.mra nor .json
          If I’m wrong, please, how I must save a route to .mra file to backup?
          • BMW F750GS
            This is definitely an iPad thing.
            Will fix later.
            • Lluis Arasanz
              Yes, is detected on iPad
              Thanks Corjan!
              • BMW F750GS
                I think it's fixed for iPad
                  @Rob-Verhoeff
                  @Lluis-Arasanz as I don’t have a tablet it works fine on the desktop. The only thing not working is sharing the url with a friend and then start the shared route with that url.
                    I’ll check in a while
                    • BMW F750GS
                      @Rob-Verhoeff i’ll try to check from my side
                      • BMW F750GS
                        Checked. Works as expected.
                        • BMW F750GS
                          @Rob-Verhoeff
                          @corjan-meijerink
                          If I share a route, by telegram for example, I sent a GPX.
                          If I open in android, it has associated MyRoute-app as application to run, then open MyRoute automàtica L y And i can start to navigate
                          On IOS, when I Click GPX, text editor is opene by default and from here, i must export to MyRoute.(Same behavior in iPad with V5 ans iPhone with V6)
                          After that second export, i can navigate as usual.
                          Pehaps is normal behavior for IOS devices...
                          • BMW F750GS
                            At this point the app indeed cannot use the file.
                            Trying to get it in 🙂
                            • Here Terrain maps style
                              Paul Scott
                              Paul Scott
                            • Migration of my data
                              Gary Clark
                              Gary Clark
                            • MRA AI Routeplanner credits
                              Anonymouse
                              Anonymouse
                            • Synchronisatie tussen bèta en classic
                              Henk Nuijens
                              Henk Nuijens
                            • Map viewing options
                              Anonymouse
                              Anonymouse
                            • Map layers
                              Peter Schiefer
                              Peter Schiefer
                            • Auf den ersten Blick bin ich sehr enttäuscht
                              Heinz-Bernd
                              Heinz-Bernd
