  4. Using tracks
Using tracks
6 Posts 5 Posters 172 Views 4 Watching
  • Berin
    Berin
    Berin
    Is it possible to do the following?
    Create (draw) a track?
    Edit a track?
    Join and split tracks?
    Thanks
    Brian McG Hans van de Ven MR.MRA 2 Replies Last reply
    • Berin Berin
      Edit a track?
      Thanks
      @Berin short answer - no, no & no
      longer answer - in the MRA web planner
      you can create routes
      you can edit the routes by adjusting/adding Shaping & Via points
      you can join routes & if you have Gold subscription you can split routes
      you can then save/export a route to a gpx file as a track
      the gpx track file can then be re-imported to MRA as a track
      Berin 1 Reply Last reply
      • Berin Berin
        Edit a track?
        Thanks
        @Berin
        No, this it not possible
        • superg
          You can transfer a track to a route and then you can go wild
          • Brian McG Brian McG
            Berin
            Berin
            Berin
            @Brian-McG Thanks - got it. Using the Offroad mode I can create a route on non-routable tracks.
            • Adrian Avram
              wrote last edited by Adrian Avram
              You cannot create a track, but you can split it or trim it and you can join multiple tracks, and just save as a new track !
              https://www.therideatlas.com/tools/gpx-editor/
              Adrian
              Berin
              Berin
              • Electric Car Travel Mode
              • Statement on map spinning
                1.6k
