  4. Electric Car Travel Mode
4 Posts 3 Posters 15 Views 2 Watching
  • Dave J 0
    I am having problems with this type of travel mode and it may be what I am doing, particularly as car and motorbike modes work fine.
    I try and set the parameters for my vehicle but the support page does not give much information:
    • Electric Car: If you drive an electric car, it's helpful that our program takes your fuel consumption into account. Enter your data here so it can be taken into account during navigation. In this mode, you won't see gas stations, but charging stations.
    This is the details I have:
    Help if it is me please and some more guidance if need be on what is required in these fields but when I use this mode for a simple A to B route i receive this:
    I am new to this EV world.
    Ducati Multistrada V4 Rally
    iPhone 15 Pro
    CHIGEE AIO-6 LTE
    Con Hennekens Rob Verhoeff 2 Replies Last reply
    • Dave J 0 Dave J 0
      Fuel consumption for an electric car? 😉
      • Level is the current level of your battery
      • Min. charge is the level at which you want to recharge I'd say about 10% of your total capacity for example)
      • min. destination is the capacity you want to have at least when you reach your destination (so you are not left with only 10% if you need to go back)
      • Ascent and decent speaks for itself I presume
      • Other consumption could be for heating or cooling for example
      I think your min-charge is way to high, and should be lower that min-destination. It has no meaning when you never want to go below 42, has it?
      Dave J 0 1 Reply Last reply
        @Con-Hennekens. Thank you for your reply but I still cannot get a route to be calculated. I do not have Ascent or Descent data though.
        iPhone 15 Pro
        CHIGEE AIO-6 LTE
        • Dave J 0 Dave J 0
          @Dave-J-0 Apparently, you need to configure some kind of charging station before you can navigate a route. At least, that is what I see when I select EV as the travel mode.
          I don’t have an EV myself, so I also have no idea what realistic values would be for the available fields. However, ticking one of the charging station types allows me to calculate a route as an EV.
            Stephen Rowland
            Stephen Rowland
          • Statement on map spinning
            1.6k
          • Electric Car Travel Mode
