  4. I can't see Road Closures
10 Posts 5 Posters 1.2k Views 3 Watching
  • Lary
    Lary
    Lary
    I ran into several road closures recently after careful route planning. I realized that MRA planner and the nav app are not showing me road closures. It does not show on my route or anywhere in the area where Google, Maps, and SCENIC do. It seems like I don't have something turned on. After searching support and the forum, I can't figure it out. here are the settings:
    Traffic map layer is on. No avoidances are selected.
    Using HERE. OSM layer but other map layers don't show it either.
    Using Compare - all three routes go right through it. Google and SCENIC go around it.
    I can't think of anything else.
    I'll try to share the route.
    Lary
    link text
    Nick Carthew Rob Verhoeff 2 Replies Last reply
    • Lary Lary
      Lary
      link text
      @Lary Where on your route is there a closed road?
      • Lary Lary
        Lary
        link text
        @Lary The road closures you see depend on what the map provider (HERE) includes in its map data. If HERE doesn’t include a road closure in its map data, you won’t see it either when planning or navigating!
          There for I always check my route in Plan.TomTOM. For this site is almost every time actual!
            @white.mouse.on.the.motorbikegmail.com
            I can’t see any difference between MRA and plan.tomtom
            • Lary
              Lary
              Lary
              I forgot to mention that the closure is just before wave point 15.
              To test the theory that HERE doesn't have this one on it's map but my settings are correct I tried another, high traffic area nearby. I compared MRA with GOOGLE and SCENIC and they all three show these delays and closures although somewhat different. I also switched between HERE, TOMTOM, and OSM. They all show the closures but only after turning traffic back on after the switch (would be nice to be able to set that as the default). Of course one must be zoomed enough to see them. SCENIC shows them all while still zoomed way out. It is also the only one that shows this back road closure. I believe it uses OSM so I thought MRA might see it with that map but not so.
              So in conclusion, it does work for me if the event is important enough, I am zoomed in enough, and I remember to see if Traffic is still selected. Does MRA route around closures during planning? SCENIC does not.
              It's a relief to have it working after spending several hours riding on back roads in West Virginia to find my way around closed bridges
              Thank you for your help.
              Lary
                You have to zoom in, in Plan.TomTom to about 200 or 300 meter to see all the closures. Did you do so?
                • Lary
                  Lary
                  Lary
                  I did discover that after a while that's why why the screen shots show it. It can be a bit annoying to zoom into that level for the whole route to check. Thanks
                  • Andreas Klump
                    Andreas Klump
                    Andreas Klump
                    I have the same problem. Card style is Here, traffic overlay is on. On the web planner, no shows of street blocking or traffic. If i move a waypoint to the closed road, i don't see any effekt. (Can't upload the reoute. Get an error code, that i don't have enough previlegs)
                      The problem will possibly be that Here has not marked the road as Closed. It seems the Here map hasn’t been updated yet.
                      That is the reason I check the route in Pan.TomTom the day I'm riding or the day before as I mentioned above!
                      Lary
                      Lary
                      Andreas Klump
                      Andreas Klump
                      • F034 Maintenance plan and cycles wrong?
                        Andy Nicholson
                        Andy Nicholson
                      • MRA 6.0.0 (532) Display schaltet um auf Standby?
                        Jack 13
                        Jack 13
                      • Event attendees
                        cerfskysky.com
                        cerfskysky.com
                      • Live connection with EV
                        Cleo
                        Cleo
                      • Route uploaden
                        Johan 5q
                        Johan 5q
                      • Track colors by section.
                        Òscar
                        Òscar
