  4. NC500 glitch
NC500 glitch
8 Posts 5 Posters 266 Views 1 Watching
  • Tenmill 0 Offline
    Tenmill 0 Offline
    Tenmill 0
    Good morning,
    I'm trying to route plan to go clockwise around the NC500 next week. The app won't allow me to travel along the A838 from Hope to Tongue. Instead it wants to divert me 100+ miles down to Achnairn to go across the other way.
    This is happening when I download others routes too, for example:
    https://www.myrouteapp.com/route/open/9062849
    Are others having the same issue? What is the solution to this problem?
    • Tenmill 0 Tenmill 0
      Good morning,
      Nick Carthew Offline
      @Tenmill-0 No problem for me, but I would advise reversing the route and doing it anti clockwise from Inverness. Then the route just gets better and better.
      • Tenmill 0 Offline
        Tenmill 0 Offline
        Tenmill 0
        I have no idea what happened but it now seems to have resolved itself.
        I’ve heard that anticlockwise is the way to go, unfortunately I’ve already sorted accommodation so need to go clockwise this time.
        That said I’ve factored in the A686 on my way back down south so I’ll have that to look forward during the less interesting parts of the 500 route.
        • Maarten v Offline
          Maarten v Offline
          Maarten v
          Hi , when you make the route you have to select “short” by planning en not leave it on “fast” . Maybe that is your problem. Always plan with “short” route .
          • Maarten v Maarten v
            Not correct.
            What makes you suggest using shortest for route optimisation?
            • richtea999 Offline
              richtea999 Offline
              wrote last edited by richtea999
              Check if Toolkit -> Disable seasonal closures. That lets you show/hide road closures as well as seasonal stuff.
              Ticking it will ignore any traffic/road closure info, and therefore tell you if there's some sort of closure that's causing the route to re-calculated to go around the problem.
              If it is, go to https://www.roadworksscotland.org/ (or https://one.network in England and Wales) and check what the closure is and whether it affects the time you'll be travelling.
              From a quick scan, it might be this (but no guarantees):
              SW100-02106101/CSD (4137262)
              Church end cottage Durness IV27 4PZ
              A838 B801 Junction Rhiconich - Rispond Road Junction, Durness
              Scottish Water
              0800 077 8778
              0345 601 8855
              help@scottishwater.co.uk
              www.scottishwater.co.uk
              [Start date] 01/09/2026
              6 Working Day(s)
              REPAIR BURST MAIN
              Maybe they finished early!
              • herman 3j 0 Offline
                herman 3j 0 Offline
                herman 3j 0
                wrote last edited by herman 3j 0
                I think you have a routing data issue rather than the A838 actually being blocked. If other routes show the same strange detour, the map/routing profile may have the road marked incorrectly or have a restriction on that section.Then try another routing profile first and check the A838 in the underlying map data. Because everything on my side works fine, also if you using fritz.box network, it can also make these issues sometime. 😙
                • herman 3j 0 herman 3j 0
                  @herman-3j-0
                  Check the second post from @tenmill-0. The route is good now.
                  herman 3j 0
                  herman 3j 0
                  Maarten v
                  Maarten v
                  Tenmill 0
                  Tenmill 0
                  • Export to BMW CRN
                  • Update 5.2.2 - Quick fix
                  • Did somebody see 5.2.2 (489) on android Yet!
                  • NC500 glitch
                  • High Contrast Maps
                    TuonoPants
                    TuonoPants
                    1.7k
