  4. Carpuride BMW unit stalling or restarting
11 Posts 4 Posters 111 Views 2 Watching
  • Sytze van der Laan Offline
    Sytze van der Laan
    wrote last edited by Sytze van der Laan
    I have an 8 month old W602BS Carpuride nav unit in a brand new BMW R1300RS cradle (’26). After like 30 minutes the unit shuts down and restarts, and keeps on doing that with a couple of minutes in-between restarts. It obviously makes the unit unusable.
    My iPhone 16 with CarPlay/Apple Maps or MyRoute (the problems occur using both apps) keeps on working perfectly in the meantime, and also works perfectly in my car, so the phone is not the problem.
    Also the unit sometimes stalls, as in stays on one point on the map while the ride continues...
    Does anyone have any idea what might cause the problem?
    • Nick Carthew Nick Carthew moved this topic from EN forum - Self Service
      Sytze van der Laan
      Hi @nick-carthew teach me, any reason for this move?
      • Sytze van der Laan Sytze van der Laan
        @Sytze-van-der-Laan I guess Nick moved it because there's a dedicated section for this kind of questions
          Sytze van der Laan
          which is? Please explain, I have an issue with being pushed around haha
            Nick Carthew Offline
            @Sytze-van-der-Laan You’re post is related to Apple CarPlay so I moved it to the correct section of this forum.
              not pushing you around. Your question went along with the move.
              The stability of CP and AA have had an update as of version 488 witch is finaly out on both Android and IOs.
              Did you install that update
                Sytze van der Laan
                Not being an IT person, what is version 488? I thought Carplay is not an app but a function of iOS? I run iOS v. 26.1.1
                Also: I am trying to narrow down what may be a hardware issue instead of a software issue. Because all navigation apps on my iPhone run fine (incl. MRA) and CarPlay works fine with all navigation apps in my car, I am inclined to think that all the software is fine.
                I was hoping to hear from other Carpuride users whether they were experiencing the same problem of constant reboots and stalling...
                • white.mouse Online
                  white.mouse Online
                  Well, I think that not the Carpuride nor the MRA software is the problem. I think that the real problem is your BMW!
                  Have you tried connecting the Carpuride to another power-source, a powerbank for-instant? Or directly to the battery!
                    Sytze van der Laan
                    yes that cannot be excluded, although the BMW is brand new. But it is the first thing I will check the coming days, powering the Carpuride with the USB-C outlet of the bike and taping it to my tank bag or something similar. See how that goes. Thanks!
                      white.mouse Online
                      Well, I do not trust BMW anymore since I bought me an brand new R1250RT with DAB- radio. After three year the still are not capable to make it work! And also the Navigation is still not working as it should be.
                      Therefore I advise you to use an external power source to test or power it directly to the battery.
                      Not over a power source that is controlled by the CanBus system.
                        Sytze van der Laan
                        OK thanks for the heads up. It will be interesting to test both, with the USB-bus and with a power bank - since it could be the USB bus or the cradle connector. It is now an elimination process!
                        Sytze van der Laan
                        Sytze van der Laan
                          Sytze van der Laan
                          Sytze van der Laan
                        • Hi again...Please help
