  4. Embedding daily routes into a whole trip route file - How do I do this?
7 Posts 5 Posters 390 Views 2 Watching
  • Tim Hearn Offline
    Tim Hearn Offline
    Tim Hearn
    Probably this is just my lack of experience with the tool but some help would be greatly appreciated please.
    I want to create a route for the whole of my Pyrenees trip from a series of day routes that I have already created but I can't find how you can import way points from one route into another, or import one route into another.
    So I have 10 separate routes defined in MRA, one for each day of the trip. I now want to add another route for the whole trip so starting point on day 1 and finish point on day 10.
    Can I cut n paste waypoints from one file (from each day) to another, can I export gpx and then import back into the file - which is the best way to do this please?
    Thanks
    Tim
    Brian McG 1 Reply Last reply
    • Brian Sprott Offline
      Brian Sprott
      wrote last edited by Brian Sprott
      Select your first route.
      Click on the four burger lines on the left toolbar
      Click "routes"
      Click "add"
      Select your route(s). I do it individually.
      Click the "+" button at the side
      Select "beginning" or "end" of where you want to put the route and click "merge"
      • Yannick AYRAULT Offline
        Yannick AYRAULT
        Ok, cela fonctionne dans la limite des points de passage car pour un trip de 4 à 5 jours il faut réduire les points et dans se cas MRA modifie le parcours total qui ne devient plus conforme au parcours par étapes.
        • Tim Hearn Offline
          Tim Hearn Offline
          Tim Hearn
          Thanks Brian, I'll give this a go and come back to you!
          • Travellexxie Offline
            Slightly better:
            Create a new route in your map with al those routes and call this route "all routes in the Pyrenes", or something oike that.
            Now for each route start from point 2 on how @brian-sprott described.
            In this way your first route isn't crippled and in your route overview, you don't see all the waypoints of route 1.
            • Tim Hearn Tim Hearn
              Thanks
              Tim
              Brian McG Offline
              Brian McG Offline
              @Tim-Hearn as @brian-sprott says add each days route via the "Routes" tab
              there is a 200 point limit to any route so if you have used more than 20 points per day your going to hit that limit trying to add 10 days
              IMO your best just creating a new route, adding the routes as @brian-sprott says but omitting the last couple of steps so you just have a pretty graphic of the route
                wrote last edited by Travellexxie
                Ok, my version 😝
                Every day has its own color.
                Brian Sprott
                Brian Sprott
                Tim Hearn
                Tim Hearn
                Yannick AYRAULT
                Yannick AYRAULT
                • Offline navigeren
                • No navigation instructions
                • Beeld loopt achter
