  4. Some strange routing - Can someone explain?
5 Posts 2 Posters 341 Views 1 Watching
  • Kirsten De Weerd Offline
    Kirsten De Weerd
    During a multi-day trip, while following one of the routes, we noticed that the route at some point took a completelty different turn from what was originally planned/drawn.
    My usual suspect would be traffic or something of the sort, but upon review I find something in the map that I cannot explain.
    When you look at the following route:
    https://www.myrouteapp.com/route/open/14061871
    The Meinkenbrachter Straße between the two waypoints is not a solid line and even with seasonal closures disabled, it refuses to take this road instead taking a 14km detour. The Traffic layer is not showing anything on this stretch of road.
    Also, turning to the Here Map Creator, I don't see this disrupted line or anything that would explain MRA not being able to use this in routing.
    https://mapcreator.here.com/navlink:74809343/?l=51.2804,8.0844,17,normal
    I'm 100% sure that when I was planning our trip, the route did follow this road. (I have overlayed the route-track into this test-route)
    Mostly for my understanding, for future planning/riding:
    Does anyone have an idea what could be going on here?
    • Kirsten De Weerd Kirsten De Weerd
      Nick Carthew Offline
      @Kirsten-De-Weerd The dashed line indicates that the road is closed because of road works.
      If you look on Google Maps you’ll see the road is closed until December 2026
        Kirsten De Weerd
        Ah, that makes sense then.
        I can't remember if we did effectively ride there or not (following the track at that point), I don't record tracklogs while riding.
        Still doesn't fully explain why the visualization in MRA is different than what can be found in the Here Map Creator. Other road closures are usually shown on the traffic layer (and can be ignored by disabling seasonal closures in the toolkit).
          Kirsten De Weerd
          wrote last edited by Kirsten De Weerd
          Come to think of it, we probably did take the detour (which was not a punishment in itself 😁)
          Goes to show, even if you check your routes as late as a week before departure, adventure is always lurking around the corner ...
            @Kirsten-De-Weerd I think that this is not showing on the traffic overlay map is because the HERE map believes that the road is under construction.
            Kirsten De Weerd
            Kirsten De Weerd
            • Verkeersinfo uitleg gevraagd
              2.5k
            • Offline navigeren
              jonathan maes 0 0
              jonathan maes 0 0
            • No navigation instructions
            • Beeld loopt achter
            • CarPlay says that I need a subscription
              Martin Garand
              Martin Garand
            • Traffic information
              RainerT
              RainerT
