  4. OSM off-road segment does not work/draw straight line
2 Posts 2 Posters 192 Views 2 Watching
  • Yannick_van_Vugt Offline
    Yannick_van_Vugt
    wrote on last edited by Yannick_van_Vugt
    The title already gives away the issue.
    Yes, it can be bypassed another way. No, it is not expected behaviour.
    With OSM planning we have the option for different segments, these segments allow for somewhat curvy, curvy, very curvy, fastest, off-road and custom. The off-road segment does not work, it should draw a straight line towards the route-point selected and speed up your work by doing it in the left hand menu, but it only calculates the quickest on-road route. Using the (universal) skip function on the route-point itself does work, but it's a lot more work when trying to create an off-road track and needing to go to each individual point to enable the skip function there. It also does not create any harmony and overview.
    📷: YannickvanVugt | 🏍️: DutchTransalp
    Guzzist 1 Reply Last reply
    • Yannick_van_Vugt Yannick_van_Vugt
      Guzzist Offline
      Guzzist Offline
      @Yannick_van_Vugt ...yes, I can reproduce it: in the segment setup it's not working. Only in the waypoint setup it works.
      I was not aware before, because if I plan for offroad, verry often route line is following pathes through the forest. Only sometimes, if the route line will not follow a path, I use the "offroad function" for a waypoint...
      Yannick_van_Vugt
      Yannick_van_Vugt
      • Export to BMW CRN
      • Update 5.2.2 - Quick fix
      • Did somebody see 5.2.2 (489) on android Yet!
      • NC500 glitch
      • High Contrast Maps
        TuonoPants
        TuonoPants
        1.7k
