  4. Skipping a Via point...
11 Posts 6 Posters 154 Views 4 Watching
  • Lenny Oundefined Offline
    Lenny O
    I just noticed that on the Nav App you can now skip the VIA point as long as it is not the first or the last one. Which is a great idea!
    I am just not sure if it only allows for the manual skip or the automatic skip will also work if you miss a Via point?
    Is that something new or it has been around a while?
    Thx!
    Peter Zehentreiterundefined Marinus van Deudekomundefined 2 Replies Last reply
    • Lenny Oundefined Lenny O
      Thx!
      @Lenny-O Via points are never skipped automatically.
      You can set automatic skipping in the settings, but this only applies to shaping points.
      However, you can also skip Via and shaping points manually.
      This feature has been available for at least two years (that’s how long I’ve been using it).
      I prefer do skip all types of waypoints manually all the time.
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
        Thx!
        @Lenny-O it has been this way since the beginning. Only shaping points van be skipped automaticly
          Lenny O
          Thanks, guys! I guess I assumed that VIAs can not be skipped in either manual or auto mode...... Duh!
          Believe it or not in a couple of years I am using the app, I NEVER needed to skip a VIA 🙂
            wrote last edited by Herman Veldhuizen
            I hope one day via points can be skipped. I use shaping points to work around this limitation. This has a side effect : all shaping points are visible, also those which do not represent anything useful and are only added to shape a route.
            note that via points can be skipped when you add a diversion to avoid a roadblock.
            Lenny Oundefined Mzokkundefined 2 Replies Last reply
              Lenny O
              Very good point! Thank you!
                Mzokkundefined Offline
                @Herman-Veldhuizen Auto Skipping Via points makes no sense. You either want to visit somewhere Via point or get their by certain roads (shaping point). If you are putting in waypoints at locations you don’t actually want to stop at, use shaping points. Keep via points that can only be skipped manually if the user chooses not to visit a point otherwise places the user wants to visit could be accidentally missed.
                Herman Veldhuizenundefined 1 Reply Last reply
                • Mzokkundefined Mzokk
                  @Mzokk As long as there is a way to a) hide points which are only created to shape the route and to b) auto skip other points which actually represent optional stops. Thats whats I need for my use cases, period. The most logical way is to have anoption to make via points auto-skippable so it makes a lot of sense.
                    @lenny-o
                    Skipping via points is a useful function because sometimes the time is not enough or the weather does something different from it than planned.
                    Pressing the function on the map on a suitable WP or SP is wonderful to drive there quickly and directly.
                      @lenny-o :
                      How about reading the MRA manual in peace .. many things are explained well there. After that there are fewer questions👋
                      Lenny Oundefined 1 Reply Last reply
                        @lenny-o :
                        Lenny O
                        @Hubert-Thoring What makes you think I didn't...... Sometimes people forget or mis-interpret the instructions or text. That's why this forum exists, no? 😎
                        Lenny Oundefined
                        Lenny O
                        Mzokkundefined
                          6.5k
                        • Skipping a Via point...
                          Lenny Oundefined
                          Lenny O
                          John S Parryundefined
                          Aiello antoninoundefined
                          6.0k
                        • MRA 5.2.1 (480) False message - since Internet is available
                          PieterGundefined
                          PieterG
                          38.5k
                        • Veekeersinfo en omleiden
