  4. Hull to Rotterdam ferry not recognised
8 Posts 4 Posters 793 Views 2 Watching
  • Ray Woodhams
    Ray Woodhams
    Ray Woodhams
    I am trying to plot a route from Barnsley in the North of England, to Spa in Belgium. My preferred route is Barnsley - Hull, P and O overnight ferry to Rotterdam then Rotterdam to Spa. Myrouteapp insists on sending me south to Dover and across the channel to Calais. I have tried different maps, and putting waymarks in the middle of the North Sea, but I cannot force the Hull - Rotterdam route. Any suggestions?
    BMcG 1 Reply Last reply
    • richard 3v
      richard 3v
      richard 3v
      wrote on last edited by richard 3v
      Simply make one route from Barnsley to Hull and another route from Rotterdam to Spa.
      If you save the ferry ports as favourites it makes the return journey planning easier.
      • Ray Woodhams Ray Woodhams
        @Ray-Woodhams I do not understand why you would need MRA to navigate between Hull & Rotterdam
        as @richard-3v says splitting the route into 2 sections is the sensible thing to do
        surely the Captain of the ferry is going navigate the wet watery bit 😂
        • Ray Woodhams
          Ray Woodhams
          Ray Woodhams
          Thanks for the split route suggestion. I should have mentioned that this is the obvious work around.
          My point in posting is that there seems to be a bug which is not recognising the Hull -Rotterdam route, even when it is the most obvious one, and defaulting to Dover-Calais.
          • RetiredWingMan
            Did you try setting your option to shortest route?
            • Ray Woodhams
              Ray Woodhams
              Ray Woodhams
              Aha, that does seem to do it - thanks very much
              • richard 3v
                richard 3v
                richard 3v
                Well thought out @retiredwingman .
                I just tried that and it works.
                • richard 3v richard 3v
                  @richard-3v you could also try setting the off road/skip function on the point you have at Rotterdam
                  this will then draw a straight line path from Hull-Rotterdam
                  richard 3v
                  richard 3v
                  Ray Woodhams
                  Ray Woodhams
                  • Online map settings
                    MartinW
                    MartinW
                  • Real-time traffic
                    Òscar
                    Òscar
                    Andy Nicholson
                    Andy Nicholson
                  • HERE map not calibrated
                    MartinW
                    MartinW
                  • Myrouteappstay
                    Bé Jeuring
                    Bé Jeuring
                  • Navigatie met DMD tablet
                  • Show on the maps's button
