  2. Export assistance
  3. [Export] Garmin
  4. Is It Me?
Is It Me?
15 Posts 6 Posters 881 Views 3 Watching
  • Mzokk Offline
    Mzokk Offline
    Do you have any AV/malware software settings that might be preventing the exporter from working? If the Zumo XT is visible in Windows explorer why don't you just put the GPX files you want to save on the device in the GPX file on the unit or the Garmin>GPX folder on the SD card in the unit? (If you have an SD card.)
    • Mzokk Offline
      Mzokk Offline
      This is what I get using Win 11 and the exporter this is not my preferred transfer route I use my phone and Garmin "Drive" usually and my "Daily" computer is Linux based so I just transfer files from MRA directly to the device.
      Click on open MyRouteAppConnector
      In the unit when detached from the Computer you get this
      When imported (and calculated in the case of GPX1.1 you get this in Trip planner.
      • Mzokk Offline
        Mzokk Offline
        Alternately you can just plonk the downloaded GPX file directly on a SD card in the device and import the route and track. I always download the track for the ZumoXT and run the track under the route to see any discrepancies.
        • Mzokk Offline
          Mzokk Offline
          The easiest way is to transfer the file from your phone.
          As long as the little Icon in the red square is highlighted your phone and device are connected and the file will send. For me this has been 100% reliable and a boon when using the XT and MyRoute app on tour. All that said I now navigate with MyRoute app and use my XT as a backup and to run tracks and proximity alerted POI's which I still have a use for and that MyRoute app is (understandably as its a niche requirement) not capable of.
          Brian McG 1 Reply Last reply
          • Mzokk Mzokk
            Brian McG Away
            Brian McG Away
            as @Mzokk says the easiest way to transfer files to your XT is to open the MRA app on your phone & send the file to the Garmin Drive app,
            it is simple & takes seconds & avoids any messing with cables or pc's
            • Mzokk Mzokk referenced this topic on
            • Marinus van Deudekom Do not disturb
              Maybe a dumb ass question but did you install the export function using MRA at least one time
              • Brian McG Brian McG
                Travellexxie Offline
                @Brian-McG oh, I love messing with cables 🤣
                • Travellexxie Travellexxie
                  Brian McG Away
                  Brian McG Away
                  @Travellexxie not so easy when your on tour & half way across the continent, several 1000's of miles from your PC 😂
                  • Travellexxie Offline
                    @Brian-McG come on, we'll buy a Goldwing 😝
                    • D A Wakefield Offline
                      D A Wakefield
                      I used the Drive app when I am away from my PC. I did have the exporter working, but it stopped with the device not found error. Thought is was my PC so rebuilt it, but got the same. I use drag and drop in windows explorer from now . Just wondered whey the exporter wasn't working as advertised.
                      D A Wakefield
                      D A Wakefield
                      • HERE maps updates
                        12.8k
                        Philip Verbeek
                        Philip Verbeek
                      • Latest version of the App?
                        1.5k
