  4. erratic routing instructions
14 Posts 7 Posters 646 Views 1 Watching
  • paul69undefined Offline
    wrote last edited by paul69
    afternoon all,
    This isn’t a complaint, just some information for others in case anyone experiences something similar.
    Route used: https://www.myrouteapp.com/route/open/10218580
    I rode the above route on Thursday. The first part of the ride is mostly motorway and dual carriageway, mainly to get away from the city before reaching the more enjoyable winding roads.
    While riding on the motorway between points 2 and 3, the app constantly tried to direct me off at every junction, onto an A road, and then back onto the motorway at the next junction. This continued the whole way until I reached point 3. Obviously I ignored the instructions as I knew how to get to point 3.
    I had already passed through points 1 and 2 correctly, so there shouldn’t have been any need for the app to reroute me to pass a missed point.
    For the first time in a long while, my phone also became extremely hot, and the app crashed several times during both the outward and return journeys. which was the same route in reverse.
    I’ve sent the log files to support in the hope it helps identify the issue and possibly improves a future update.
    For reference, I’m using an iPhone 12 Pro with a Carpuride CP. I normally use this setup for commuting and single-day rides. For multi-day tours, I use an RT3 rugged tablet with navigation next installed.
    offline maps in offline mode
    5:2:0 473
    K1600 GTL
    Oukitel RT3
    iPhone 13 Pro, carpuride 702b
    • RetiredWingManundefined Online
      77 kms is a long way between waypoints. Allows the navigation software an opportunity to select a shorter route. Add a few more waypoints and that will likely solve the issue.
        hi @retiredwingman
        think you may have misunderstood the post.
        I know the way to waypoint 3. the fastest route will always be motorway, hence why I do not need more points.
        I was merely pointing out that I was directed off and back on the motorway at every junction.
        I have ridden this same route a number of times, it was only on this occasion, interestingly since the latest update, that it behaved like this.
        K1600 GTL
        Oukitel RT3
        • LE DIZES Freddyundefined Offline
          LE DIZES Freddy
          Hello
          Are motorways permitted?
            @le-dizes-freddy
            yep, but even if they were not permitted, it would not explain the fact of instructing me back on to the motorway.
            I could see the route highlighted ahead, on my screen. attempting to take me off then back on.
            I am not new to this app, and I would consider myself quite an experienced user, I was just pointing out the behaviour, and as stated above, the same route has been done previously without this issue.
            I think it was having a bad day, as my phone got really hot, not done this for a long time, and the app crashed a couple of times later in the ride.
            K1600 GTL
            Oukitel RT3
              I would say it's in the settings of your Navigation Next.
              Although the route has not that many shaping points that doesn't explain why it tries to get you of the motorway.
              That could be the result of the settings in NN.
              Could you share your settings
                It's just a guess, but if could be HERE map behavior. More than once, I've experienced strange things directly attributable to HERE itself. Again, this is just a guess, but something to consider.
                  Did you make the route with the webplanner. I see that the route is with the Here map.
                  Did you by any change made it with the OSM and then later on concerted it to Here.
                  I know that OSM does tricks like you've explained with motorways.
                  If you started with OSM you can't het rid of that behaviour
                  John S Parryundefined 1 Reply Last reply
                    wrote last edited by John S Parry
                    @Marinus-van-Deudekom interesting observation on OSM. I do sometimes change the base map from OSM to HERE if I decide I need to execute the route on the phone. I haven't experienced issues, but good to know it's a possibility.
                    What I have experienced is a route on a long/straight USA interstate (think I-5 in California), where HERE will have me exit and re-enter the freeway for no apparent reason. I had no waypoints that would have triggered the behavior, but it's happened more than once. The response in the past when I've reported it that it's HERE doing it under the covers and MRA has no control over that behavior. That was of course comforting. 🙄
                    My solution over time has been to develop using OSM as the base map, which I've found far more stable/predictable than HERE. It works well most of the time, because I export the GPX and use a Garmin Zumo XT for most of my route executions. This won't work with the app execution since the route must be developed using the HERE map as base. Again, just something to consider.
                    • paul69undefined paul69
                      hi @retiredwingman
                      Brian McGundefined Away
                      Hi @paul69 I have tried simulating driving your route multiple times & can't repeat the behaviour your seeing,
                      in fact I get the exact opposite, at every junction it is telling me to stay ON the m-way or main A-road
                      My guess is somehow when you started the route MRA glitched & changed a navigation setting in the background so the route was recalculated to do something abnormal
                      As @marinus-van-deudekom says this effect has been know in the past when someone created a route with the OSM route calculator but we can see in this case you have selected the Here route calculator so it is odd
                      I think the only way to try & figure out what is occurring is if you can re-ride the route & get a repeat of the issue then save the app log file for the devs
                      It looks like a decent ride to Hawick so should not be to much of a hard task 😂
                      LennyOundefined 1 Reply Last reply
                        LennyOundefined Offline
                        @Brian-McG That's a nice screen! What device is this?
                        • LennyOundefined LennyO
                          @Lenny-O its an android simulator on PC, not a mobile device
                            @Brian-McG hi Brian. Could you share the name of the program on your pc
                              I always plan my routes on the web planner, and use Here, I do compare with OSM and tom tom while making them. I also use the Michelin overlay as the Here is very wishy washy, and bad contrast.
                              perhaps I inadvertently changed it, but I do not know why I would do that.
                              as stated above, I have ridden the route previously (3-4 times) without issue. I have sent the logs.
                              when I have ridden the route before, that is what normally happens.
                              For info to all, I merely put this on here as discussion point, and to highlight the behaviour, although it is good to read the differing points of view.
                              I am touring around Ireland from Thursday, no motorway to speak of so may not see this again.
                              it is a very nice route, although the road between Middleton and Alston is very uneven, not great on my K1600, almost throws me out of the seat in places, enjoyed it more when I had the GSA
                              @marinus-van-deudekom,
                              I use fastest route in optimisation, the rest is below
                              K1600 GTL
                              Oukitel RT3
                              LennyOundefined
                              paul69undefined
                              LE DIZES Freddy
                                Steve Jarrellundefined
                                Steve Jarrell
                                4.8k
                              • Nieuwe functie: OSM-zoekcategorieën per voertuigtype [5.2.1-486]
                                PeterKerkhofundefined
                                PeterKerkhof
                              • Route spoor gpx
                                supergundefined
                              • Updated beta! 5.2.1 (486)
                                594
                              • Track vs Route
