  4. Need to adjust Time based on speed limits.
8 Posts 5 Posters 140 Views 3 Watching
  • Richard 4jundefined Offline
    Richard 4j
    I assume travel time shown is based on posted speed limits. In the USA cars and trucks generally travel faster than speed limit at a minimum of 5 mph and motorcycles are 10 mph on streets and rural roads. On the interstates motorcycles are 10 to 15 mph faster than posted speed limits or 80 to 85 sometime 90 mph in 70 mph speed limit in rural areas.
      My guess is that you cann’t ask the Devs team to do something against the law
      Richard 4jundefined 1 Reply Last reply
      • Richard 4jundefined Richard 4j
        Brian McGundefined Offline
        @Richard-4j travel times are actually calculated from data the map providers have for the average speeds of traffic on each segment of road,
        so a busy road with a speed limit will probably have a lower average speed than a quiet road with the same limit,
        speed limits are not really a factor except for the fact that they supposedly regulate the upper limit of speed 😂
          this is a very reasonable request.
          i stopped using another app because the times were not accurate and the app did not offer an option to apply a correction.
          wether it is technically doable or not is another question.
            Richard 4j
            @Marinus-van-Deudekom
            It's not against the law at least in the US that allows a user select the his actual travel speed when planning a route.
            24 Transalp 750, dyno tuned.
            22 CB500X totaled off roading
            Racing sailboats Lake Erie
            1974 Montesa Cappra 250 VR , 2 cycle, 36 hp,
              Richard 4j
              @Brian-McG
              I understand the cartography companies include the government posted speed limits in there data. The MRA program is using that data to determine the travel times. I'm only requesting that MRA consider changing the software so their customers can adjust the travel time to the actual speeds they expect to travel at, be it faster or slower, to determine more accurate ETA time.
              • Leike Lodiersundefined Offline
                If you see you're travel time and you now you will be speeding.then you will be there earlier.
                  @Brian-McG
                  Correct
                  Incorrect, travel times are calculated on the average speeds that road users actually manage to drive on the actual roads. You obviously did not read my post
                  Yes I fully understand that you want a user adjustable factor so you can adjust your expected times
                  but you don't really need MRA to provide that factor,
                  you can just learn how far out the current MRA times are compared to your travel speed & work it out
                  Richard 4jundefined
                  Richard 4j
                  Herman Veldhuizenundefined
                  • Update 5.2 - Persistent Map Items
                    Lluis Arasanzundefined
                    Ruurt Visserundefined
                    Ruurt Visser
                  • Probleem met gedeelde route
                  • Autonomous smartphone management
                  • Sharing Routes and Tracklogs
                    Dae 0undefined
                    Dae 0
                  • New version 5.2 questions
                    Keith Hofgartnerundefined
                    Keith Hofgartner
                  • Font for the distance to the next turn to smal
                    Ed Lauwerens 0undefined
                    Ed Lauwerens 0
                    2.4k
