  4. Sharing Routes and Tracklogs
sharingroutetracklog
14 Posts 6 Posters 829 Views 1 Watching
  • KevN1k 0undefined Offline
    KevN1k 0
    A suggestion about sharing these. I like to keep my routes and tracklogs private but coming from another app, I liked to be able to share the link to my private route/tracklog and be visible to whoever has the link, without the person having to have an account nor being in my friends list.
    • nomkoundefined Online
      You can share routes with folks outside MRA. You just need to set the route/track to public and then share the link to this route/track.
      If (for some reason) you don't want people sniffing around in the folder that specific route/track is placed, you can create a separate folder for sharing routes and have only that folder set to public as well and share your routes/tracks from that folder.
      | MRA Gold Member |
      | MRA Next + Kawasaki Z650 |
      • Bart De Medtsundefined Offline
        Just create a folder that is set to private and put all your routes in it. Then you can choose for each individual route whether it is private, visible to friends, or public.
        If someone visits your profile, they won’t see any routes. However, if you share the link to a public route with someone, they will still be able to access that route.
        Keep in mind that your routes may still be visible in the app’s activity feed.
          KevN1k 0
          That's the thing, I don't want my routes to be visible to anyone unless shared through a link, this is what I'm suggesting as an addition to MRA.
          I don't want people to be able to find my routes through the search nor by my profile. But, let's say I planned a group ride and want to share that ride with the group, which are often nor just friends, I want everyone to be able to see the shared route without having it visible to everyone, it's pretty simple.
          • KevN1k 0undefined KevN1k 0
            @KevN1k-0, create an event then 😉
            KevN1k 0undefined 1 Reply Last reply
              KevN1k 0
              @Con-Hennekens thanks for the suggestion but you’re missing the point..
                @KevN1k-0, Well maybe you should explain yourself more clear then. Events are what sharing routes to non-friends is all about, people can apply for an event, or you can select whoever gets acces yourself.
                  Dae 0undefined Offline
                  Dae 0
                  @KevN1k-0 I understand clearly what you want, I think. It’s like the feature in Scenic (my navigation app of choice) whereby all my routes are private but I share a link with anyone and they can view the route and export it to GPX. When I say anyone, I mean just that - they don’t even need a Scenic account.
                  MRA can’t do this.
                    No that's not correct. In the bottom you'll find a possibility to share that scenic route
                      KevN1k 0
                      wrote last edited by KevN1k 0
                      @Con-Hennekens apparently i’m clear enough as @dae-0 nailed it! Scenic is also my go to app, for now but I’m here suggesting some features to be added to MRA app and I’m being given “alternatives” instead… while clearly my OP starts with “suggestion”!
                        This is why it is possible
                          Dae 0
                          wrote last edited by Dae 0
                          @Marinus-van-Deudekom
                          The OP specifically wants to keep the routes private, as we can do in Scenic.
                          In Scenic the recipient of the link can see your route, even though it’s private and not discoverable in any way to someone without the link.
                          The recipient doesn’t even need a Scenic account - the link takes them to the web portal where they can view it, import it into their own Scenic (if they have an account), or download it as a GPX.
                            wrote last edited by Con Hennekens
                            @KevN1k-0, funny how people want to keep routes private, but at the same time want to enable unrestricted access through a link... Thank you for your downvote while I truly wanted to help you out.
                              KevN1k 0
                              @Con-Hennekens I down voted because your comment was arrogant! I'm asking for a feature request through a suggestion as is this part of the forum and all you did was give me an "alternative" to later be arrogant... but I'll give you the benefit of the doubt, for language barrier.
                              KevN1k 0undefined
                              KevN1k 0
                              Dae 0undefined
                              Dae 0
                                Steve Kelly 0undefined
                                Steve Kelly 0
                                Albyusundefined
                                Albyus
                                Jon Hye-Knudsenundefined
                                Jon Hye-Knudsen
                                John S Parryundefined
                                Adrian Avramundefined
                              • A few observations
                                Thomas Miklundefined
                                Thomas Mikl
