A routing issue
I am fine tuning a tour round Europe at the end of June and I'm having a routing issue. According to google maps the route is open but MRA isn't allowing it, even with seasonal closures disable.
I want to do this route from Sembrancher to Saxon.
https://www.myrouteapp.com/en/social/route/12505317?mode=share
@Mark-Coughlin Move 13 a little closer to 14.
Can't believe that I didn't do that as I normally do, but the massive diversion made me think that there had to be a problem.
Thanks
Mark
@mark-coughlin
What is the setting of your route optimisation? Have you set it to Fastest or to Shortest?One will have a different approach to a route than the other.
If the route optimisation is set to Fastest: yes the route will be as shown in your screenshot because the route could be faster between points 12 and 16.
But set to Shortest, the route should go from 12 to 13 to 14 to 15.Something to check as well
I'm planning a trip also..i have the same issue's. Its since the last update.
You need to set a lot of more points on the map to direct the rout.
Whit the last version it just would go via Schonsee en Eslarn
Uhmzz oke strange then, i never had did "issue" before.
