  4. Carpe Iter BMW Controller issue
6 Posts 3 Posters 1.4k Views 1 Watching
  • Steve Jarrell
    Steve Jarrell
    Steve Jarrell
    I have the Carpe Iter BMW 4 button control, and a DMD T865X tablet on which I'm running MyRouteApp. The BMW "Wonder Wheel" will zoom the map in and out, but the only button that works out of the 4 is the bottom one. That button brings up the routing menu which I can't exit unless I touch the screen instead of panning the map which it's supposed to do.
    I have the Carpe Iter connector software set to its single profile setting (MyRouteApp) instead of automatic and I have the Carpe Iter BMW Control set as my interface in MyRouteApp. Obviously the controller is paired properly as the control wheel zooms the map in and out, and one button does work although it doesn't do what it's supposed to do.
    I do have the DMD OBDII bluetooth dongle installed and I thought that may possibly be interfering with the CI controller, but since it's working reliably zooming in and out and the bottom button consistently works I doubt that's the problem.
    I have opened a support ticket with CI but I thought I'd check here as well. I LOVE both the DMD tablet and the MRA app combination, but the CI interface would make it even better if I can get it to work as advertised.
    Does anyone have any suggestions on what else to try? Does anyone have the Carpe Iter control working reliably with MRA?
    Thanks,
    Steve
    Steve Jarrell
    Western North Carolina US
    2025 BMW R1300GS
    2025 Can-Am Spyder
    DMD T865-X 8" Tablet
    Garmin XT3
    • Steve Jarrell
      Steve Jarrell
      Steve Jarrell
      I got it to work!
      I changed the input setting in MRA from Carpe Iter BMW Controller to just Carpe Iter, and in the CI Controller app I changed the "auto detect" setting and chose just MRA.
      The Wonder Wheel works as a zoom up and down control, and a quick tap to the left brings up a very useful CI menu that allows you to lock and unlock the screen, adjust the brightness and volume, etc. A quick tap to the right will change the perspective from overhead to an angled view and back.
      The buttons pan up, down, left and right. Zooming with the Wonderwheel will re-center the map.
      This is exactly the functionality that I was hoping for.
      Steve Jarrell
      2025 BMW R1300GS
      2025 Can-Am Spyder
      Garmin XT3
      Chudy 1 Reply Last reply
      • Steve Jarrell Steve Jarrell
        I got it to work!
        Chudy
        Chudy
        Chudy
        @Steve-Jarrell Gu Question It's controled via wunderwheel or via "extra" controller ?
        • Chudy Chudy
          Steve Jarrell
          Steve Jarrell
          Steve Jarrell
          @Chudy Both.
          Here's a link to a post by @corjan-meijerink regarding the integration. My previous post also explains what the Wonder Wheel and the buttons do on my bike.
          Here's a picture of mine.
          Steve Jarrell
          2025 BMW R1300GS
          2025 Can-Am Spyder
          Garmin XT3
            @Chudy Both.
            @Steve-Jarrell are you using the carpe iter controller app or carpe iter ngh app. with the NGH app you can arrange the buttons the way you like them. For example you can use the 4 button controller to skip a waypoint or center you're card or to set you're sound.
            • Leike Lodiers Leike Lodiers
              Steve Jarrell
              Steve Jarrell
              Steve Jarrell
              @Leike-Lodiers The only things that I can do with the buttons and the Wonder Wheel are what I posted before. I do not use the app. There may be more functionality that I haven't discovered but this is all that I do with it for now.
              I'll have to experiment with the app(s) when I get a chance. Thanks for the information!
              "The Wonder Wheel works as a zoom up and down control, and a quick tap to the left brings up a very useful CI menu that allows you to lock and unlock the screen, adjust the brightness and volume, etc. A quick tap to the right will change the perspective from overhead to an angled view and back.
              This is exactly the functionality that I was hoping for."
              Steve Jarrell
              2025 BMW R1300GS
              2025 Can-Am Spyder
              Garmin XT3
              Steve Jarrell
              Steve Jarrell
              Chudy
              Chudy
              • Audio cuttet via Bluetooth
                Haug
                Haug
                35.5k
              • One crash today
              • Download club route folders
                Mosimann
                Mosimann
              • Elektrisch rijden
                John mq
                John mq
              • Zoom level issue
