  4. Navigation stopped working during Tour
89 Posts 24 Posters 29.9k Views 9 Watching
    Another 1000 km with the latest MRA version without any issues.
      Thanks for sharing. I will contact Ulefone. Maybe they take it back. I just liked the brightness of the screen. Regards Thomas
      @Thomas-Neumeyer as a last resort. Did you try setting it back to Factory settings and then start from scratch. Seems weird that you’re the only one with troubles. Maybe it works
        Additionally, are there any other apps running in the background?
        • Thomas Neumeyer
          Thomas Neumeyer
          Thomas Neumeyer
          I made factory reset two times and no, there are no other apps in background. I also just installed myroute app to avoid any issues. I contacted Ulefone, lets see how this works. Strange is just that all other Apps for navigation are working.
          • Thomas Neumeyer
            Thomas Neumeyer
            Thomas Neumeyer
            And it seems that at least another user has the same problem with Ulefone.
            • Marinus van Deudekom
              What does Ulefone say.
              If they dont offer a solution mabey MRA support van help out via a ticket
              Thomas Neumeyer 1 Reply Last reply
                I translated it. Its a different problem. The routing stops and the position arrow does not move anymore. Closing the app does not help. It's asking if I want to continue the tour but its not follo8my movement. Only after several times closing the app it works but not for good and stopped again. So far no news about my ticket sent.
                I experienced exactly this last weekend. I cannot say it was temperature but it was hot. What is says above matches exactly my experience. Swipe-closing the app did not help, rebooting the phone did. Probably a force-close from the Android Apps menu would have solved it to. For me, this is the only resembling experience I had during a 4 day ride. I blame the phone... 😉
                  Thomas Neumeyer
                  Thomas Neumeyer
                  Thomas Neumeyer
                  @Marinus-van-Deudekom First answer was a question since when this is the case....
                  • Thomas Neumeyer
                    Thomas Neumeyer
                    Thomas Neumeyer
                    I got some feedback from Ulefone, they stated it is the app with some incompatibility and I should use some other navigation app. 🙂
                      That was way to easy for them to blame the other party instead of investigations it themselves.
                      • Thomas Neumeyer
                        Thomas Neumeyer
                        Thomas Neumeyer
                        That's true, but it seems to be the case that I am not the only one with issues. I am just at the moment at home and I have no longer trip planned. Last two weeks I made 4000 km and it was not a perfect experience with Ulefone/MyRoute. Check still the Samsung.
                          You could sent a ticket including the logfiles. Maybe tech support can take a look at it just to be shure
                          • Thomas Neumeyer
                            Thomas Neumeyer
                            Thomas Neumeyer
                            I did this already. Nothing they can find.
                              Then report that back to Ulefone
                                Qualo
                                Qualo
                                Qualo
                                @Thomas-Neumeyer
                                Yo he devuelto la tableta. Lo que más me interesaba era la luminosidad de la pantalla, como a ti. Contacté con ulefone y me ofrecieron devolución o intentar averiguar que ocurre.
                                Decidí saber wue ocurre, pero el método era probar de nuevo grabando desde mi móvil y activar el modo recopilación de Android.
                                Finalmente la devolví, no tengo tanto tiempo para eso...
                                I returned the tablet. What interested me most was the brightness of the screen, like you. I contacted ulefone and they offered me a return or try to find out what is happening.
                                I decided to find out what's going on, but the method was to try again by recording from my phone and turn on Android collection mode.
                                I finally gave it back, I don't have that much time for that.
                                After summer (too hot to route all day...) I will consider a Samsung Active Tab 5, an Android screen or stick with my old Samsung S21 that works perfectly.
                                  @Thomas-Neumeyer, or you should use another phone... I guess you told them that too? 😉
                                  • Bouke Ent
                                    i have ulefone armor x10 and that runs MRA now fine without any problems. mine runs android 12 i believe and there is not much bloteware on it. i run 5.1 beta. my only problem is spinning screen when standing still but that is a know Here problem.
                                    with version 5.0 i had some problems like craches/freese or delay but with 5.1 i work good.
                                    i only use phone for MRA and i do not play music. no AA and no recalculation.
                                    • Thomas Neumeyer
                                      Thomas Neumeyer
                                      Thomas Neumeyer
                                      I will keep it for the moment. Maybe there will be some updates and in future it will work. Try out Samsung Active 3 which I still have and test it. Thanks for your tips and feedback.
                                      • 4
                                      • 5
                                      Òscar
                                      Òscar
                                      guenniguenzelsen
                                      guenniguenzelsen
                                      Léon Hassing
                                      Léon Hassing
                                      OGRIII
                                      OGRIII
                                      Thomas Neumeyer
                                      Thomas Neumeyer
                                      TuonoPants
                                      TuonoPants
                                      Qualo
                                      Qualo
                                      Raul Arteaga
                                      Raul Arteaga
                                      Chalkster 0
                                      Chalkster 0
                                      rofowe
                                      rofowe
                                      Scottish Biker Abroad
                                        Nick Elsom 0
                                        Nick Elsom 0
                                      • 0 van 15 klaar
                                        Mark Vroomen
                                        Mark Vroomen
                                        Bart van de Griendt
                                        Bart van de Griendt
                                      • Routelijn transparantie
                                        Mark Vroomen
                                        Mark Vroomen
